can anyone tell me where this is located on the engine? ive heard there is a grren on and a blue one? does it matter which one i get? i have a a3 1.8 tqs
I changed the coolant temp sensor on my S3, im not too sure about the set-up on the A3 1.8 T.
Check out the link below this was for a TT http://www.wak-tt.com/tempsensor/tempsensor.htm
If it is the same then, it's a 5 min job, be careful make sure the engine is cold and release the lid on the water coolant. I lost alot on my coolant and had to replace the coolant which is not a bad thing.
