Monster MotorsportChris Nott
Results 1 to 21 of 21
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    window wont close
    you lot all get to play in the snow
    i have to get my window back up
    heard thats its a comon problem,
    read a few threads, question am asking, do i have to remove the sub frame ???
    and anyone got any pics of what i need to fix or replace ?
    thanks
    happy snowball fighting
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    seen this thread but pics have gone
    Faulty S3 Electric Window Fix
    Still need Remap
    2007 Audi S3 8L
    paul_brad's Avatar
    Apr 2004
    Leicester
    365
    mine did that Rick about a month ago!
    Took it to Lion Garage (near Holiday Inn roundabout in town) where I always go for work done on the Audi. new mechanism and labour cost about £130 I think though .
    If you're confident in taking your door apart, go for it. Its a blue plastic thing thats snapped, if memory recalls from the pics on the posts.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    £130 way to much for me,
    am very confident taking it apart, (and i do enjoy it)
    ive been using the guide but one of the torx screws is very hard to take off, so i have to wait for weekend when there is more light to play with,
    i think the blue clip roughly costs £5
    but thanks for the reply paul
    Still need Remap
    2007 Audi S3 8L
    bena3turbo's Avatar
    Genuine Dude
    Oct 2006
    Wirral
    90
    mines done the same. itll go down ok, but it comes back up on an angle and then decides to go back down.
    I tried taking the door apart but I couldnt remove it completely. Its as if its been glued into position as well as screwed.
    Go banana!
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by bena3turbo
    http://www.piglet-net.net/tech/cars/a3-window.html
    use that guide, or have you actaully fixed it or you still having problems ?
    Still need Remap
    2007 Audi S3 8L
    Dec 2006
    190
    Theres a post on here somewhere with a link on it with pictures, i used that when i did mine just before xmas. From memory you have to take the door card off, disconnect all the electrics and remove the subframe. I got re-enforced clips i think they was about 3 each. I did the other clip on the same window while i had the door apart. If you have a memory like me you might find it usefull to code the male and female parts of the electrics so that you plug the right thing back into each other when you put it back together. Its not a hard job at all mate, you'll be fine doing it yourself. Any probs let me know.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    what tool did you use to take the torx screws off from the sub frame ?
    am finding it very difficult what to use, could you show me a picture or upload one from me please
    Still need Remap
    2007 Audi S3 8L
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I had this on mine. Used a torx key - like an allen key, but with a torx head on it, and a torx socket from my socket set.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    ive taken 2 out, the bottom 2
    but the top ones wont move, and the one nearest to the mirror, is the hardest one to get to.
    if you can upload a pic of the tool you used, would be very helpful
    Still need Remap
    2007 Audi S3 8L
    Dec 2006
    190
    I just used a torx bit with an extension bar and a ratchet, came out no probs.
    Dec 2006
    190
    Sorry mate didnt see that last post. The screw nearest the mirror is on the side of the subframe isn't it? To do that one i just took the extension bar off and used the torx bit and the ratchet. What tool are you using with the torx head on it??
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    am using this, or similar
    and ive put a mole grip one the end to turn it, still wont turn, Also put WD40 on
    the top 2 are doing my head in, oposit to the mirror side wont budge at all, and looks like the star shape is damaged inside, wont open and keeps slipping, but if i wanted to tighten it, it doesnt slip at all
    Still need Remap
    2007 Audi S3 8L
    Dec 2006
    190
    Either the bolt has rounded off or you are using the wrong size torx bit. try using a ratchet instead of a grip, if you havent got the adaptor to put between the ratchet and the bit then you can use a 10mm socket. Should give you a bit more leverage using that.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    got a rachet but cant find the adapter, will try again on the weekend as am busy tomorrow,
    Where did you get the part from ? audi ?
    and whats the part called and how much was it
    Still need Remap
    2007 Audi S3 8L
    Dec 2006
    190
    I take it you mean the clips? I paid 1.67 each trade for them, got 3: 2 for the window and 1 for spare. Also when you are putting the torx bit into the bolt make sure that it is really pushed into the bolt before you start to turn it. If you are finding it hard to get the ratchet in between the door and the bolt (for the bolt next to the mirror) you could try putting a spanner on the hex part of the torx bit and turning it like that.
    Dec 2006
    190
    Sorry didnt read your question properly. I just asked for the clips that are on the window regulator which attach to the glass and they knew what i was talking about. The part no. that i got was W4B0837463B and is described as a carrier on the invoice.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    not that expensive then which is good,
    ahh spanner might do the trick, ill see if i can find one now,
    cheers mate, but will update back on the weekend
    Still need Remap
    2007 Audi S3 8L
    Toxik-Signal's Avatar
    Andy
    Oct 2006
    Nottingham
    357
    I've got this problem too on my passenger side
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by Toxik-Signal
    just follow the guide mate
    Still need Remap
    2007 Audi S3 8L
    bena3turbo's Avatar
    Genuine Dude
    Oct 2006
    Wirral
    90
    mines still broken. will have a look through the guide. thanks for that!
    Go banana!
