Sky InsuranceAH Fabrications
    patras, Greece
    Audi S3 tachometer to A3 1.6
    I am an owner of a Audi A3 1,6 sports and i would like to use the DIS function.
    I was thinking to change my existing instrument cluster with a S3 dash so as to have the little display unit.
    Does anybody knows if the S3 dash is compatible with my instrument ???
    Is it just plug and play or it will need more wiring??
    1,361
    Re: Audi S3 tachometer to A3 1.6
    A few of us have looked into this before, but it just seems too complicated to do, and would expect it would be complete harnesses that would be needed in conjunction with the instrument cluster.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I may have been able to have told you one way or the other but I've been out bidded on ebay twice. Most of the ones that appears are off the facelift and/or in Kph and so are unsuitable for me. There was a chap who sold the loom, sensors and cluster altogether but a guy bought it outright seconds after the bidding started [img]/ubbthreads/images/graemlins/mad.gif[/img]
    Khufu's Avatar
    5,693
    There may be hope - if you speak German. http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=38729
    Feb 2003
    Lincolnshire/Bournemouth
    739
    I've just sent a DIS conversion kit across to a friend in America.
    To convert to DIS you need to cut the appropriate sub-loom from a donor vehicle. DIS is fully inegrated into the car loom, and hence you need to cut relevant wires. Fitting involves removing the dashboard and soldering the new DIS loom in, along with connecting a relay.
