Chris NottJMB Retrofits
Results 1 to 9 of 9
    Jan 2007
    7
    S3 2002 bose system retro fit
    I've just brought myself a bose system for my s3 2002 model and was wondering if anyone's fitted one to a s3 without the bose system before?
    i'm sure the speakers will be no problem, even the twin sub looks like the wiring looms the same, i think the amp gonna be the problem.
    please advise were the amp's ment to be located, and if anyone know's if the looms is standard for such a upgrade? if so where will i find it.
    thanks 4 your time guys
    bams3
    Jan 2006
    UK
    160
    Might be a better post in the 8L S3 forum, but maybe someone does know on here as there a few 8L S3 > 8P converts ?
    05/05 Audi A3 (8P) Quattro S-Line 3.2
    Jun 2003
    World of my own
    9,813
    That's a major job.
    None of the wiring is the same so all of it has to be replaced. So that's the loom from the HU to the boot, including the front/rear pre-outs power for the amp and the speaker loom from the boot to the front & rear speakers. If you have the looms then it's still a painful task. If you don't have the looms then forget it. The upgrade is pretty pointless anyway as the Bose system is only slightly better than the standard system (have you looked at the Bose replacement rear speakers? They are presumably taken from an old WWII valve radio).
    You'd be much better going aftermarket, or at least adding just a sub (or stealth sub) and upgrading the front components. Much less work and it'll sounf a million times better.
    Probably not the answer you were looking for, but at least you know before you start that it's a pretty hopeless exercise.
    Jan 2007
    7
    not a great answer but a very helpful one thanks..
    how about if i run the system without the amp?
    its not gonna be running at the full watts the amp has to offer but still might be a lil punchier with that double cone sub and better made speakers?
    thanks again
    bams3
    Jun 2004
    Surrey
    595
    I wouldn't bother with Bose having had Bose and non-Bose. Get yourself one of Andy's stealth subs. It sounded a lot better than Bose.
    Oct 2006
    22
    i agree. although the head unit looks good if you wire a decent amp and sub in the system actually transforms really well.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Apologies for the blatant post hijack, but I wondered if anyone who originally had a BOSE system in their A3/S3 and has subsequently upgraded the front speakers as AndyMac suggests still had them spare?
    I've blown the driver's side woofer and would like to replace it with another BOSE item if anyone has one spare. Thanks.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Jun 2003
    World of my own
    9,813
    The HU is identical whether Bose or non Bose, it's just got a flatter EQ (set on the back by grounding the Bose/GALA pin), thus the absolute lack of any real variance when you up the treble or bass settings.
    On the sub front, yes the Bose sub is better, but not punchy in any way shape or form. Woolly is about as good as it gets and by replacing the stock non Bose sub you lose the rear speakers as they run off the same amp that's inside the sub.
    I tried exactly the same thing before designing my stealth sub. The Bose sub is more powerful at 100w, but it's the enclosure that's the problem, it uses the same tupperware box as the non Bose unit.
    So you'd need to customise the sub loom to get the feed and wiring into the Bose sub (as the plugs are completely different), then extract the amp from the non Bose sub and link it up as well to give you the feed for the rear speakers (or buy a small 2x25w aftermarket amp and use that). You'll then be straining the power cable on the non Bose loom as it's only rated at 5 amps, so you'd need to run some additional power. For all that work you'll have a marginal improvement in more woolly bass.
    Jan 2007
    7
    cheers andymac bang on with the advice
