Chris NottEM Tuning
Results 1 to 14 of 14
Thread: soft pedal
    Jan 2007
    soft pedal
    just bought a 2000 s3 and the brake pedal is soft! just wondered if this a common thing or that my brakes are dodgy
    rodenal's Avatar
    Oct 2006
    1,982
    Theres not really any feel through the A/S3's brakes if thats what you mean?
    Otherwise it prob just needs new pads and possibly discs
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Ed
    Ed's Avatar
    Oct 2006
    Farnham
    185
    What were you driving before?
    I drove my mates ford puma the other day and the brake pedal felt really hard compared to mine!
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    You could try bleeding the brakes, or changing the fluid.
    Feb 2004
    2,036
    When i replaced the low but not shot at pads in my mk 4 (std pads S3 size) I was amazed at how much harder the pedal felt!
    So may be that, also fluid and lines should eb checked. There have been incidents of the banjo washers on the rear brakes of Mk4 golfs failing the first sign is a smally weep, , then suddenly with no warning the pedal goes to the floor as the washer corrodes through, relaing the pedal presuure and fluid! Caused a few scary moments for some golf guys, may be similar on the S3 of same vintage!!
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    Mine went very soft after having a brake fluid service. Used to travel 1" before bite, now more like 4".
    Sep 2006
    In the Westcountry
    185
    Quote Originally Posted by NEiLS3LK51
    Is the pedal travel shorter without the engine running?
    Air can easily remain trapped in the system, if the correct bleeding procedure isn't followed.
    Dec 2006
    mine quite soft aswell after it had a fluid change by audi but my rear discs and pads are low so im gonna change them first
    Sep 2006
    In the Westcountry
    185
    Unless you are experiencing a long pedal, rather than spongy one. It could be a seized caliper. The usual problem is the rear caliper carriers binding on corroded pads. If you pries them out and clean them up with a wire brush, it should cure it.
    It is worth a look anyway.
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    I had just changed the rear pads and discs before the service. AMD dude said there was a lot of water in my brake fluid before it was changed.
    I can't check the pedal travel with the engine off at the moment as the car is in the body shop, will do when I get it back.
    Feb 2004
    2,036
    A lot of water..../ And yet the pedal was better before.....!? Sounds suss that!
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    Suss that the job was not done properly?
    Jan 2007
    cheers for the suggestions will maybe try discs and pads as the system has be bled and copper slipped. what are best sort of discs n pads to go for?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    my brakes seem to be getting worse everyday. When braking hard they seem to make a whining noise not very loud but hearable. All pads have been replaced.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
