Chris NottSky Insurance
Results 1 to 11 of 11
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    KEY AND LOCK PROBLEMS!
    When i bought my S3 i only recieved one key (flip type)
    but it dosent fit the airbag key switch
    and it will lock the drivers door but not unlock it! wierd realy! cant get my head round it, will also lock the boot but not open it
    is it possible i have the valet key or something? work in ignition fine
    any help appreciated
    Ash
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    Mo-S3's Avatar
    North West
    706
    Your key may have been cut from the original but not done correctly hence why its not opening/closing all the locks.
    If you want it perfect then you need to get Audi to do it with the codes from Germany. Expensive? Well hell yeah!!
    rodenal's Avatar
    Oct 2006
    1,982
    Yeah you will probably need a new remote key, circa £150 fully programmed from audi iirc
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    can it be done without the code tag thing that i havent got!?
    All i had with the car is one flip key
    rodenal's Avatar
    Oct 2006
    1,982
    If you buy it from audi, they can code it themselves, all they'll need is the car for an hour(not sure if you can maybe do it yourself too if you get them to supply the key)
    Mo-S3's Avatar
    North West
    706
    I bought a blank and got it cut from a local VW dealer and my Audi dealer kindly supplied me a key fob and programmed it for me free of charge! yes FREE!! Just depends on how friendly your dealer is.
    Jun 2006
    712
    thats sounds like a very friendly Audi dealer!
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    Quote Originally Posted by Mo-S3
    Christ! If only all dealers were this generous!
    I get all my parts discounted but thats only cause im there nearly every week! lol
    Aug 2003
    Christchurch, New Zealand
    47
    When you buy the car you get two identical fully functioning flip keys and one plastic key of last resort.
    I put one flip key in a cupboard, and have been using the other one full time. The plastic one is attached to the one in the cupboard.
    If the key is failing to open, and only close then that's (AFAIK) a physical lock issue.
    I'd have a locksmith have a look at the key, and check whether it works fine on the passenger door. Maybe it's possible to change the key without changing the fob (the expensive bit)?
    Cheers, Ed.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    The reason it works in the ignition and not the doors is probably because the ignition lock is worn and a lot more tolerant of a discrepancy in the key than the doors and boot which normally rarely get any use so are less worn and therefore less tolerant.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    thanks guys
    Think il have to get the dealer to look into this, dont wanna be locked out with a flat battery again!!
