Volks AutosSky Insurance
    HSM
    Jul 2003
    Losing power on 2nd???? any ideas
    Hi,
    i've got a A3 1.6 1998 S, a little problem with the gears and revs i think.
    what basically happens is when setting off in 1st gear and then changing to 2nd at around 3000 revs or more, you can feel the car pull back on power as if there is a big elastic band on the back and once taught the car is pulled back.
    you then change gear from 2nd to 3rd at between 2000 - 3000 revs the power starts to regain again gradgually.
    any ideas why this is happening???
    Thanks.
    06 A4 2.0T FSi S-Line SE
    Nov 2003
    London (N8)
    515
    Re: Losing power on 2nd???? any ideas
    my 1.6 does this (1999 T reg)
    not sure why...?! i'm going to try an ecotek valve soon, so i wonder if that will help...?
    Feb 2003
    107
    i had the same problem on my other car which is not an audi, and my garage changed something 2do wiv the throttle regulator.
