Chris NottEM Tuning
Results 1 to 11 of 11
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    Average MPG at idle??
    Hi, I recently noticed my avergae fuel consumption dropping, like a stone (ie from a long term ave of about 26-28 down to 20 and then a little later 17.6). So I put air in the tyres reset the ave MPG and drove it home, apart from recording very low MPG I noticed the AVE MPG counting down whilst stopped at traffic lights, the decimal places were counting down at a rate of 1 per second. I never watched this before but i feel I have a problem, anybody know if this is normal? If it isn't what could be causing this loss?
    Cheers in advance, I darent take it out at the moment
    Imola S3 looks normal but isn't
    Dec 2006
    N.Ireland
    369
    its normal... how can you be getting any miles per gallon when stopped?
    so the computer has e.g 20mpg on it for the last 1 mile journey, you stop at lights for 2 minutes, your using part of that gallon, but not having any miles done.
    i wouldnt worry about it, if you are, you need to lay off the loud pedal a little, or buy a 1.5 diesel corsa :P
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    It will drop like that just after having reset the DIS, as claude explains. if you are worried it's change significantly I'd get it at the very least to someone with VAG-COM to check for any faults.
    How many miles are you getting from a tank / has that changed?
    Jan 2007
    116
    This doesnt sount right to me to be honest. Id get it checked if I was you. I get 33mpg with a mix of city driving and 80mph motorway.
    2003 52 plate Audi S3 Imola Yellow
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    Quote Originally Posted by god_thats_quick
    I dont know what I am getting per tank as this has only just happened and I've just filled the tank. Normally I get around 250. Anybody in Kent got Vag Com
    fasteddie's Avatar
    Jul 2005
    Ashford, Kent
    204
    Quote Originally Posted by Kef9
    33mpg? Are you sure it's an S3 and not a TDI?
    Jul 2005
    2,488
    i get about 17-19 mpg, and about 200-250 a tank. 90% city driving. Goes up to about 27-30 if i go on a long run.
    Jun 2004
    Crowthorne, England
    2,512
    We've been here before but I pretty much always get over 300miles to a tank, did manage 401.6 but then ran out...
    My journeys are a mixture of motorway and fast A roads, when I managed over 400 that was pretty much all sticking to speed limits on the motorway.
    Jan 2007
    116
    Quote Originally Posted by fasteddie
    Ill take a photo of my dashboard to show you if you want!
    Dec 2006
    N.Ireland
    369
    i can also show one around 31mpg
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    I get 250miles to the tank if I'm being sensible, but the DIS says 28ish.
    Freaking injectors!
    [/sarcasm]
