Monster MotorsportBadger5
Results 1 to 10 of 10
    Dec 2006
    bleed valve on 1.8t
    quick question, does anyone know if a bleedvalve will work on a 1.8t s aldon automotive said it would but im not sure
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    Please don't fit a bleed valve on your 1.8T.
    Go and get yourself an Escort RS Turbo if you want to do that sort of thing.
    A decent remap is the only way if you want more boost/power/torque IMO.
    dubhyper's Avatar
    Illegally Street
    Aug 2006
    B/wood
    128
    yup yup i agree
    remaps may cost alittle(x20) more, but youll have all sorts of problems with a bleed valve..So no they are not suitable.. Unless anyone knows otherwise
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I think bleed valves only work on cars that don't have electronic engine management. It may drive the ECU haywire.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Dec 2006
    i thought that it would'nt work aswell but they reckon if i set it at 14 psi and have a remap it will be fine
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    daft question coming up: whats a bleed valve?
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Between the compressor housing and the wastegate actuator is a small rubber pressure hose, when the turbo boost pressure reaches a pre-defined level it activates the actuator and opens the wastegate. The wastegate operates in such a way that it allows exhaust gases to bypass the turbine blades, therefore slowing the turbo and reducing boost.
    A bleed valve fits on the rubber hose between the actuator and compressor housing and bleeds some of the pressure out to the atmosphere thus reducing the amount of boost reaching the actuator, this allows higher turbo boost to be acheived.
    Chris
    See my images @
    Sep 2006
    In the Westcountry
    185
    Any sort of boost controller other than the N75 will negate any control your ECU has over boost.
    If your ECU detects certain problems it will try to limit boost to prevent engine damage, it will not be able to if the N75 is disabled.
    If you are planning a remap anyway, just forget about the bleed valve, and get the car mapped by someone who knows what they are doing.
    A bleed valve may cost pennies, but the damage could cost £££s.
    dultanur's Avatar
    Sep 2006
    Istanbul,Turkey
    407
    totally agree with secret squirrel. the end results could be horrendous or nothing at all, just limp mode.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by Secret Squirrel
    Haha...
    I though the exact same thing...
    Bleed valve = chavtastic RS Turbo with mahoosive exhaust and spotty, large gold rope-chain & Burberry wearing youth slumped behind the wheel.
    Don't do it...
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
