Sky InsuranceBadger5
    Nov 2006
    Onchan, Isle of Man
    9
    and now...Clicking / Knocking
    Hi all,
    My first post after lots of lurking; great forum.
    I hope some of you can shed some light on the following.
    S3 2000 (210bhp)
    No modifications apart from the 18" Alloys.
    Car is relativley new to me.
    So, I had the lateral acceleration sensor throw up an error on VAG COM, got a new sensor, cleared the fault - all going well. Started planning my next maintenance tasks.
    Around the same time I became aware of a click/knock while pulling out of the drive in the morning. Noticable at low revs just as I'm letting out the clutch, especially on a slight hill. The rate of the sound increased with the engine revs / or the wheel revolutions.
    A few days later the oil light popped on on the way to work, I should have check earlier but there we go... So I filled it up and almost immediately I noticed this noise was less common.
    Been a couple of days now and the noise is intermittent. I have heard it while stationary with the drivers door open gently reving the engine, at other times doing the same thing I can't hear it. The garage I bought it from are off ordering ARB bushes - i suspect they are deaf, but that's another story.
    Any thoughts?
    T
    Dec 2006
    N.Ireland
    369
    front bushings?
    Nov 2006
    Onchan, Isle of Man
    9
    Finally got the car back today, with a new block and some other refinements.
    Turns out the "knocking" was a shattered middle piston ring on the 3rd cylinder; I now have it in a plastic bag to remind me of the pain. The conrod on the same cylinder was also slightly bent; as a result of the piston ring there was oil residue over the valves and manifold port.
    Contemplated replacing all the internals - opted for the new block from Audi with 12 months warranty.
    T.
    Jun 2006
    712
    just shows you should check your oil at least once a week
    Feb 2004
    2,036
    How much was the block from Audi if you dont mind me asking?
    Did it fail big time or did you have it stripped and inspected?
