Results 1 to 23 of 23
Thread: 95 / 98 RON ???
    Durham
    15
    95 / 98 RON ???
    Greetings S3 lovers,
    My S3 is due in a few weeks and I'd like to know whether it is worth continually using a "better" grade fuel such as OPTIMAX or can I run it on your common or garden unleaded without any side effects. While I'm here I might aswell ask whether the BOSE sound system I've ordered makes much difference? Any advice to a future S3 owner is appreciated.
    Jack.
    Chepstow, South Wales
    620
    Re: 95 / 98 RON ???
    [ QUOTE ]
    Jack.
    [/ QUOTE ]
    Hi Jack
    Some contentious issues here!
    - Optimax vs. Unleaded: The general concensus is to stay WELL away from Supermarket petrol - it's full of rubbish [img]/ubbthreads/images/graemlins/shocked.gif[/img] You will find some people on here that use Optimax religiously, and others (like me) who just use regular unleaded and then pop a tank of Optimax in every now and then. So I think it's just a case of sucking-and-seeing [img]/ubbthreads/images/graemlins/smile.gif[/img] Personally I can't tell the difference between normal unleaded and Optimax, but other people say they can - up to you really...
    - BOSE: I have it, and I wouldn't be without it. To my ears, it's much better than the standard set-up. However, others have gone for the standard set-up and then spent a similar amount to the BOSE upgrade on aftermarket products and got a better sound that way. Having never heard any of these I can't say whether I would find them better or not, but having said that the BOSE in my S3 does just fine for me [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Hope that helps...
    Alex.
    89
    Re: 95 / 98 RON ???
    Where I am I have no option but use standard unleaded and the car performes perfectly well.
    The Bose sound system is a good sound I find and I have changed the head unit from the Chorus to a Kenwood mask and the sound difference was greatly improved. The Chorus is made by Grundig and not a patch on the Kenwood. I definately recommend Bose as I also have Bose in the house.
    Bucks
    1,038
    Re: 95 / 98 RON ???
    Go for Optimax every time...... [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    And as far as BOSE is concerned.... I don't find the sound quality very good, but it is a lot better than an Audi non-BOSE.... depends how important sounds are to you!
    1,361
    Re: 95 / 98 RON ???
    I have to strongly disagree with Alex's statement of Supermarket fuels being full of rubbish........Supermarket brands do not differ from that of the major oil companies and in a lot of cases I'm sure are made by these major brands!! 95 Ron Fuels differ by very little between brands, only in the additives a certain manufacturer adds, nothing else.
    Do you see Safeways (UK) doing their own research and refinement? They just sell the stuff.
    Optimax is undoubtedly a better fuel, the higher octane rating it has means it has more power for the same amount of fuel compared to standard unleaded, it also boasts superior cleaning abilities over the standard. Cleaning is important to keep the rubbish (tar etc.) that there is in fuel from gunking things up, valves, piston rings etc.
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: 95 / 98 RON ???
    well I WORK in a Q8 site and I dont buy the fuel. I used to work for Esso, and happily bought that fuel but now I get optimax even thought I only have a 1.8 sport. As said, its the post refinary additives that makes the difference.
    104
    Re: 95 / 98 RON ???
    Silvers3UK
    I guess you don't like jags then. All I can say is don't try race one off the lights in your 'oh so high tech' S3. And how's a 400hp/400lbft 4l 32valve supercharged V8 a lazy low tech engine. Drive one then criticise.
    I'll have to check the article again tonight, but from memory the BM and jag had mostly been run on supermarket super, pre optimax.
    I'd also consider 0.1-0.2 secs on 3sec increments quite an improvement. That corelates to about a 5% increase in power.
    The Type R had been run on 95UL so the difference was more marked.
    Run mine on optimax 95% of the time with SUL when I get caught out. There is a significant difference in performance compared to 95, both in feel and against the clock.
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,707
    Unleaded V Super Unleaded
    Quote Originally Posted by GolfTTish View Post
    Silvers3UK
    Bit of an old post I know but was bored started flicking throught the oldies to this.
    So my question is, is there a noticable difference between Unleaded and Super Unleaded or is it neglegible.
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    i switched to Vpower 2 months ago, get better consumption even though its more 's, and the car seems to run ever so slightly better..... only gave the stuff a two tank trial as was unconvinced it could have much effect.... never going back to 95
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,639
    V Power all the way, i started using it a couple of days after i got my S3 and i wouldnt go back to normal unleaded, it costs slightly more, but it has its benefits, as i get about 60 extra miles off it compared to normal unleaded, albeit most of my driving is on the motorway, so its EVEN better...the car also feels more responsive with it.
    TFSI's Avatar
    Born to Fish
    South Cheshire
    527
    V power all the way It does seem to give better MPG and it runs sweet and you get a free Ferrari
    2013 1.4 TFSI S line 8V, Brilliant Red, Cruise Control, DIS, MFSW, Dual Climate, Leather, Front Fogs, 18in 5 Twin Spoke Alloys, Welly, Boot and Fishing Rod Racks.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    i have just started collecting my second set lol......
    Nilz's Avatar
    Apr 2006
    9,639
    Haha, forgot to mention them, i have completed my 1st set, and am 2 cars away from my 2nd set, hopefully they will be worth millions in a few years....lol
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    V Power for me as thats what mine was mapped for.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,607
    robbing *******s have put it up two pence a litre since last week FFS
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    V-Power for me as well..in fact I've used nothing else since I got the car.
    Has anyone else been lucky enough to get 2 Ferraris with one tank fill-up? I did the other day cos the guy behind the counter liked my car
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    bl_1969's Avatar
    Roads? We Dont Need Roads!!!!
    Apr 2008
    351
    My 2 cents...
    Got my 2003 A3 TQS In October last year, was using standard unleaded without issue in U.K.
    Drove it out to Eastern Europe and the whole place has RON100... Not Netherlands or at least I did not see it. Germany, Czech Republic does tho. So anyways, it's also cheaper here so started using Shell V-Power Racing (RON 100) and the difference is amazing. I get better MPG, like seriously better MPG. The car seems to run a bit quieter, and there is a marked difference in power. Then went back to U.K., got it Revo remapped, drove back out and when on the good stuff it really does go! I would not use anything else.... but I have to when I hit Netherlands and U.K. tho
    Winter is cold cold here (Czech) so that has been helping too with the performance. Summer is coming in, had the air con on last week and I reckon I will see a decrease in performance... at least thats what I have read and been told.
    I would recommend Shell, read somewhere that 5th gear program done a comparison and they to saw a benefit to it, especially with turbo's.
    There you go, thats me said my bit.
    Car: A3 1.8T QS (ARY)
    Mods: Revo Stage 2, Milltek, K&N, Forge 007p, B8's & Eibach Springs, 312MM OEM Brakes, BBS LM's, Light Pack, Ally TT Pedals, New Audi Gear Knob, Int LED's
    Wish List: ARB's, FMIC, Hose's, Maybe A Clean Engine Bay and Free Petrol
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Quote Originally Posted by themanthatcan View Post
    Got two last week, put 59 litres in but the lad gave me two as im always in there
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    OPTIMAX... Better consumption than v-power!!! tried and tested ppl!
    Feb 2008
    2,810
    love V-power. increase in performance was there seemed smoother ( although dont know how much is psychological) but def better mpg.
    i got 2 ferraris in one fill up!!
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Quote Originally Posted by scott_johnson View Post
    V-Power is just the renamed optimax isnt it
    bl_1969's Avatar
    Apr 2008
    351
    Yeah, I think they just ditched Optimax and renamed it to V-Power, at least that is what I have read on some other forums. I am no aficionado though.
    If in doubt about it (whether it's worth it or not), you could always run the car till empty, fill up with the standard stuff and take note of MPG and performance. Use the whole tank... then fill up on the premium V-Power or V-Power racing if thats in the U.K. yet and see whats what. I definitely get better MPG and as mentioned by some other people, seems smoother drive but that could just be the placebo effect I suppose
    Nilz's Avatar
    Apr 2006
    9,639
    As mentioned before, i have got a lot better mpg on v power compared to normal unleaded and i always use Shell Petrol.
    Also, i also believe that Optimax has been renamed to V Power - i think it was something to do with the Ferrari branding....
    One more thing, i just about get one car, as they never have any in stock, might try my luck with 2 next time as i always fill about 55ish litres, so not far off!!!
