EM TuningMonster Motorsport
    May 2004
    170
    Cam belt change time
    Right I am ringing around to get prices to change the cam belt on my S3 as its due a changing.
    Firstly prices vary wildly! but thats not wht I am after
    Ive decided to price the bits on vag parts but Im not sure exactly what I need and they dont do waterpumps either!
    I know I need the belt obviously, but they list two types of tensioner and a damper??
    S2Avant's Avatar
    Jan 2006
    Yorkshire
    56
    Get your engine code and ring VAGparts, Martyn is very good.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Try GSF http://www.gsfcarparts.com/ I got my belt kit (belt, tensioner and idler) for about 70 quid, also got waterpump from there for about 25 quid. They also do G12 Coolant for 5 quid a bottle, you'll need 2.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Feb 2004
    2,036
    I would use GSF again.......great service and good prices all OEM equivalent, some even have identical casting marks, just in diff boxes!
    Change everything........all rollers, belt, tensioners, ( ask for the kit with the the hydraulic tensioner thingy) waterpum, get the metal impeller one if you can (brass). It was about 150 quid for it all IIRC, but just not worth all the labour and not change things.
