Results 1 to 10 of 10
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    radio advice needed...
    Dear all,
    My radio reception is pants (2001 S3), having looked around i have concluded that, yes, the water has got into the booster circuit inside the aerial base.
    Now, ive tried to dry it out and even replaced the seals from VAG parts but to no avail.
    Audi stealer has quoted my 50 for a new aerial base with the electornics in. The advice i need is
    1, should i now go DAB, if so how - whils maintaining original stereo ?
    2, if not - where else could i get the part, 50 sound like alot.
    any idea's
    cheers.
    Call of Duty Zombie Slasher.
    VeeDub Geezer's Avatar
    Ex-20v Coupe Owner
    Nov 2006
    Aylesbury, Bucks
    90
    id say try a salvage yard (normally 10-15 pounds) for a replacement aerial
    as for DAB i think you will have to either change the stereo or fit a Revo box (not that Revo... lol)
    http://www.revo.co.uk/store/in-car.php
    HTH
    WWW.DubDynamics.Com - Come Say Hi!
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    same happened to mine, i paid 55 quid all in at a local radio specialist and it took them about 2hours to do and the reception is crystal clear
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Jun 2003
    World of my own
    9,813
    Audi moved the aerial amp on A3/S3's from the beesting base to the HU in about 1998 as they were getting so many failures and it was a pig of a job to replace. So you'll probably find just using an active antenna amp will cure the problem.
    http://www.caraudiodirect.co.uk/aeri...tor-p-211.html
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    I would not recommend the Revo.
    I got one a year ago that came with a really cr@p windscreen antenna that has never worked acceptably.
    If you leave the thing plugged in to the cradle overnight it will happily drain your battery for you.
    Jun 2003
    World of my own
    9,813
    "If you leave the thing plugged in to the cradle overnight it will happily drain your battery for you."
    Only if you've wired it up incorrectly to a permanent live. Hardly the fault of the Revo. A mobile phone or Road Angel will do exactly the same.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    I've got a Revo, wired correctly to the ignition live , as Andymac pointed out, and connected to an external aerial on the rear-window. It's fine.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    The Revo manual says in the installation manual in two places to connect "to the vehicle's power supply" and twice "to vehicle 12V power supply".
    In prior experience of fitting such things, instructions in other manuals use words like accessory or switched when they don't mean use a permanent live.
    Perhaps the person who wrote this manual missed that by mistake if they meant switched.
    But, further to that the Switching on and off instructions state "When you first fit Revo into its cradle it will be in standby mode with the display blank and no sound playing.
    Revo will also be in standby mode when the vehicle's ignition is switched on." Would that not be off instead of standby in the first instance when a switched supply is used?
    NEiLS3LK51's Avatar
    Jul 2004
    West London
    188
    jdp, you say yours uses "an external aerial on the rear-window", is that because you could not get the interior antenna supplied to work acceptably either?
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    do vagparts do a replacment base cheaper?
    2000 s6 avant, special order met, green, satnav, Bose, tv, solar roof, privacy glass, recaro silver nappa.
