radio advice needed...
cjhill
hmmmmm interesting.
UK, South
Dear all,
My radio reception is pants (2001 S3), having looked around i have concluded that, yes, the water has got into the booster circuit inside the aerial base.
Now, ive tried to dry it out and even replaced the seals from VAG parts but to no avail.
Audi stealer has quoted my £50 for a new aerial base with the electornics in. The advice i need is
1, should i now go DAB, if so how - whils maintaining original stereo ?
2, if not - where else could i get the part, £50 sound like alot.
any idea's
cheers.
same happened to mine, i paid 55 quid all in at a local radio specialist and it took them about 2hours to do and the reception is crystal clear
I would not recommend the Revo.
I got one a year ago that came with a really cr@p windscreen antenna that has never worked acceptably.
If you leave the thing plugged in to the cradle overnight it will happily drain your battery for you.
"If you leave the thing plugged in to the cradle overnight it will happily drain your battery for you."
Only if you've wired it up incorrectly to a permanent live. Hardly the fault of the Revo. A mobile phone or Road Angel will do exactly the same.
I've got a Revo, wired correctly to the ignition live , as Andymac pointed out, and connected to an external aerial on the rear-window. It's fine.
The Revo manual says in the installation manual in two places to connect "to the vehicle's power supply" and twice "to vehicle 12V power supply".
In prior experience of fitting such things, instructions in other manuals use words like accessory or switched when they don't mean use a permanent live.
Perhaps the person who wrote this manual missed that by mistake if they meant switched.
But, further to that the Switching on and off instructions state "When you first fit Revo into its cradle it will be in standby mode with the display blank and no sound playing.
Revo will also be in standby mode when the vehicle's ignition is switched on." Would that not be off instead of standby in the first instance when a switched supply is used?
jdp, you say yours uses "an external aerial on the rear-window", is that because you could not get the interior antenna supplied to work acceptably either?
12
508
486
6
15
