Sky InsuranceEM Tuning
Results 1 to 9 of 9
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Question Will ET35 BBS wheels fit an S3?
    Just wondering if 18x8.5 +35mm offset will fit me 2002 S3?
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    I'm not sure how much space you actually have in your S3 arches unfortunately (maybe one day!), but you can compare to the OEM Avus here...
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Regards,
    Rob.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Yup, they'll fit...
    But, beware of what size spacers you run at the front.
    If you NEED to run spacers to clear the brakes for example, and run a lot lower than standard, you may be close to rubbing, or rubbing with 8.5" wide ET35 wheels and 10mm spacers.
    I reckon you should just be Ok...but 15/16mm spacers will most likely cause rubbing.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Defratos's Avatar
    May 2004
    2,230
    I c, thanks for the help I think I'm gonna go with that
    Audi S3-BAM
    Feb 2004
    2,036
    8.5 by 18 ET30 will fit, (BBS CHs). So 35's will be fine, wihtout spacers.
    Defratos's Avatar
    May 2004
    2,230
    anyone looking for 20mm rear spacers? lol
    Audi S3-BAM
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by simch
    With an 8.5" et35 you'll be getting close to the strut on the inside.
    [/sarcasm]
    Defratos's Avatar
    May 2004
    2,230
    Quote Originally Posted by ChriS3
    Ok, what's the strut on the inside? I wanna know how these wheels will sit in the archs and how it'll change handeling. Do u know if it'll damage the strut on the inside? only reason I'm after these wheels is because I've seen them on another S3, but can't get hold of the exact rim spec.
    Audi S3-BAM
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    It's the suspension strut you'll be gettin close to. Have a look at the link FactionOne posted, that'll show you how the wheel sits in the arch. As for a change in handling, thats also dependant on wheel weight, offset, width, size, and so on.
    [/sarcasm]
