Badger5Volks Autos
Results 1 to 10 of 10
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    URGENT HELP needed, fault on dash!!
    Can anybody shed any light on what this may be? Ive only just recently had a service so id be suprised if i was low on oil, ive just been out and checked and it seems fine, thing is ive gotta pick dad up from airport 2nite and dont wanna screw my car up by drivng it!
    Thanks in advance
    German iz ze vay forvard!
    Made with vorspung durch tecnik
    2003 Noggy S4 Avant - 344bhp of pure V8 muscle
    Darthvader's Avatar
    "The Darkside"
    Dec 2006
    Sunny Scotland.
    153
    could be a dodgy oil/water temp sensor???
    "If it's broke, Upgrade it"
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    reckon it will be ok to drive?
    it flashed up a few times before but i just turned of the engine, fired it back up again and it disappeared, said OK.
    But now its on all the time! may have a trip to stealers in the morning
    Darthvader's Avatar
    "The Darkside"
    Dec 2006
    Sunny Scotland.
    153
    Quote Originally Posted by Booth_S3
    check the oil, if all is ok then i dont see why not, also make sure your heaters are blowing hot air on idle.....
    Defo go to the dealers in the morning, or get 1 very helpful local, to run VAG-com tonight for you
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    Quote Originally Posted by Darthvader
    What would that mean if they aint? thanks for your help mate, dont know anyone local tbh
    Darthvader's Avatar
    "The Darkside"
    Dec 2006
    Sunny Scotland.
    153
    if they are cold, then there is a blockage in the system or a failing headgasket, other symtoms are the temp gauge shooting up... I wouldnt worry about this, as i dont think thats your problem..
    I honestly think it's just a dodgy sensor, as they seem to be the only thing that is consistently temperamental on the Audi's...
    Mo-S3's Avatar
    North West
    706
    The oil sensor is mounted under the car on the sump. See if you can get under it and check the connection. It ight just be dry/loose. Failing that i would try the dealers first thing in the morning just to be safe.
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    Right, the light went out last night before i had to go to the airport, i picked up a bottle of oil just in case thought!
    When i got home i check in the manual and its a faulty oil level sensor. Popped in to the stealers today that wanted to get my car in a VAG COM it at £60, never! I just asked how much a new sensor and labour would be. They quoted me £120 does this sound reasonable or am i best sourcing the part myself and fittind it DIY.
    Or shall i just leave it? Do you need and oil level sensor?
    thanks
    Jaywoo_A3's Avatar
    Audi dead, 2.0T all the way!
    May 2006
    Derbyshire
    509
    Its a easy enough job to do if its the same as a A3.
    Just drain the oil (filter should be ok if its just been serviced)
    disconnect the plug on the senser,
    undo the three bolts,
    replace with new senser,
    connect up senser and fill oil back up.
    Like Mo-S3 said the senser is mounted on the bottom of the sump.
    Booth_S4's Avatar
    Riding on V8 power
    Oct 2006
    Newcastle, Staffs
    657
    may have a stab at DIY then me thinks!
