hi all,
all my lights seem to be failing at once, but as far as i can see, all the bulbs are intact. I've had one sidelight not working for a while, but if you open the bonnet and 'twiddle' roughly round where the bulb is, it comes on, and stays on for the journey. But then the next day it probably wont be working again.
That's been fine till now, as the same side headlight has now gone! It seems to be permanently gone, but on inspecting the bulb the filament is still attached both ends.
Also over Xmas I had an itermitent brake light, which appears to have worked for the past few days (The DIS will beep at me, then dissapear when breaking again as its now working, then beep again a bit later as its bust again)
Is it a case of changing all the bulbs? Taking it to a garage? I feel a bit silly going to Audi specialist with a broken bulb.
I'd really appreciate if anyone has had a similar thing, or any advice they could give. cheers
