Chris NottVolks Autos
    jediknight's Avatar
    Nov 2004
    Cambridge
    834
    how to remove an S3 seat??
    still cant find the source of my fecking rattle. so out with the seat and see if i can get to it then
    anyone know how it comes out though before i head out there and spend hours messing with it.
    ta
    Age 18: CRX MK2 | Age 20: Corrado VR6 | Age 21: Audi S3 (rip) | Age 23: Audi S3 | Age 25: BMW E46 M3
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,052
    Khufu has a concise workshop manual for the interior online here:
    http://myweb.tiscali.co.uk/macnee/downloads.html
    Regards,
    Rob.
    EDIT: The short version though; there should be a trim panel on the front-side of the base of the seat which you can pop-off (my pre-owned Recaros didn't have them though) - once you've got that off you should see a plate with either two bolts and a locating pin of sorts, or one bolt and two pins (memory failing me). Undo the bolt(s) there and push the seat towards the back of the car (but carefully though - there are stilll electrical connectors hooked-up underneath you don't want to damage ) - once you've got the seat back far enough you should be able to manipulate it to get better access to the electrical connectors so you can un-hook them (precision screwdrivers come in handy here for undoing the cilps on the connectors as they're a bit fiddly).
    Regards,
    Rob.
