Volks AutosMonster Motorsport
Results 1 to 7 of 7
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Bulb Warning after HID install
    I know a lot of people here have retro fitted HID lamps for dipped beam.
    I used a serious vision kit supplied by JBR Performance and although its very good quality its a generic kit so the instructions aren't perfect.
    How do you get around the bulb out warning on the DIS? Can I switch it off via VAG-COM or is there something I can short?
    <Insert meaningless geeky specs here>
    Oct 2006
    Norway
    37
    hooking the hids up with a relay, would most likely do the trick
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    You need to wire in a resistor to fool the bulb check circuit.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Yeah, I already used a relay circuit but you still take the original connectors out of the loop by wiring in HIDs.
    I resistor would certainly work but does anyone know which value I should use?
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,052
    First let me say that this is NOT based on something I've heard/read from someone who's actually had this problem and used a resistor to solve it. I've just used power and resistance maths to have a stab...
    If I understand what you're trying to do (fool the DIS that you have a normal bulb completing the circuit when you actually don't) - I guess it would be something like...
    a) If you're drawing power from somewhere else entirely and are just using a relay which will draw negligible wattage from the original circuit, and you need to simulate a 55W Halogen bulb sitting on the 12V line; that would require a 2.618 ohm (if we're splitting hairs ) resistor if my maths doesn't fail me.
    or (less likely I guess)
    b) If you have a 35W Xenon bulb somehow on the lines where you used to have a 55W Halogen bulb) - you need to connect the circuit and simulate an additional 20W draw on the 12V line - that would require a 7.2 ohm resistor.
    Anyway like I say, that's more science than experience, but I think I'm on the right lines...
    Regards,
    Rob.
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,052
    http://www.sengpielaudio.com/calculator-ohm.htm
    That should help if you want to check or alter the numbers
    Regards,
    Rob.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Cool, thanks!!
    Black
    B********
    R***
    Our
    Young
    Girls
    But
    Virgins
    Go
    Without
