Thread: VIN Number
    markyp2002's Avatar
    Oct 2006
    Burntwood
    301
    VIN Number
    where is my VIN number located? A3 2001 T Sport ?
    A4 B7 2.0 TDi S-Line Special Edition Gloss Red, BOSE, 18" Black RS4s, Black / Grey Leather, Sat Nav
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    should be on the left or right corner of the windscreen
    look from the outside
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    rodenal's Avatar
    Oct 2006
    1,982
    or in the bootwell or under the bonnet
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Feb 2004
    2,036
    On the windscreen as said and on a sticker in the boot floor which should match to the sticker in the service manual.
    Its also stamped on the top of the firewall in the engine bay, sort fo drivers side to the middle, and should be visible througha clear plastic window on the platic scuttle pkanel. If dirty, you may need to carefully lift the scuttle panel to see it, DONT lift the clear plastic, it will shatter!!
    Interestingly enough on prefacelift cars, this number si clearly stamped direct into the metal on the firewall. On facelift cars (pretty sure, certainly 2002 cars on) is seems ot be stamped into a weird factory fitted soft metal "sticker style strip and is brighter ands easier to see. Forst time I noticed it I panicked, it looked real dodgy like it had been doctored (cheers audi dealer I thought!!) but a check on other facelift cars shows this is who they do it now!
    Sort fo scary though, if plod ever looked hard at it, he may talke you in cos it looks well sus!
