dultanur said:
tallpaul, i beleive the 1.8t will increase boost in response to warmer inlet temp. in order to produce the required power. you can see this difference between summer and winter. but i'm not sure if it can compensate completely...
eitherway, your car will have to work harder to make the same power...
No, no, no...
The ECU requests a given boost level...the N75 modulates to try to achieve this boost level. That's it...summer or winter...the requested and delivered boost IS THE SAME.
However...in summer the air is hotter, hot air means hot inlet air which means hot air into a hot turbo which equals even hotter air to the ICs.
Hot ambient air passing accross the ICs equals incomplete cooling of the hot compressed charge and the ECU pulls the timing back to prevent engine damage.
This effect is felt on hot days...or similarly as heat soak.
It's just felt as power loss at the top end.
In winter...the air is colder (the colder the better), cold air means cold air into the inlet, which means cold air into a hot turbo which means the compressed charge isn't as hot as it is in summer.
Then cold ambient air passing accross the ICs equals much better cooling of the hot compressed charge so the ECU sees much colder charge air temperatures at the inlet manifold and doesn't need to pull the timing back to prevent engine damage....so you get a much harder top end surge.
All engines benefit from cold air breathing and cold ambient temperatures...turbos more so then NA as they benafit x2 (inlet and IC efficiency).
There is no change in delivered boost summer to winter...only changes in the way ther ECU drives the engine based on air temperature (very simplistically)
If you drill your airbox, you feed a humgry engine hot air...summer or winter...as it gets hot under the bonnet of a 1.8T car (any turbo'd car) and so you reduce the power being made.
That's simply the way it is....
More noise, less power.
De-tuning. Not smart. In fact...very dense.
If you want to mess with the airbox, give it a nice big (4") cold air feed from the area of highest pressure just behind the front bumper skin...then you get lovely cold air and a (very) slight ram-air affect at daft speeds.
Don't drill the airbox...
