Results 1 to 27 of 27
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Upgrading the brakes on A3
    Had my car mapped a few months back and am now considering improving the brakes to handle the extra horses.
    It's putting out 162bhp so i don't really see the point in going for something like the brembo kit as the benefits would be negligable IMO (also it's quite an expensive option)
    I'm now thinking of changing the brakes to those used by the TT & S3 - 312mm if i'm not mistaken -has anyone else done this and if so any idea how complicated it would be and how much it's liable to set me back?
    Alternatively i could go for an aftermarket setup so if anyone has any suggestions it'd be handy.
    Mike
    Feb 2006
    Lincolnshire
    719
    Hello, I got a kit from this ebay seller...
    http://cgi.ebay.co.uk/312mm-Brake-Co...QQcmdZViewItem
    They are off delivery mileage Audi TT's I believe, but I went this route because all the bits were new. You could probably source the same parts for a lot cheaper from a breakers or similar though.
    Fitting was easy/ok, even for somebody who'd never done it before (like me!), and I upgraded the hoses to braided items at the same time. I used a pressure bleed type thing to bleed the brakes afterwards, but I was surprised how little fluid escaped during the change, so it didn't take long.
    Power wise, not as dramatically powerful as my bro's Brembo setup on his Leon, but a useful increase in power and fade resistance from my 288mm setup, and I would say worth it for the cost of the above kit. Even more so as my old pads were shot anyway.
    I'm not aware of any other options before you start getting into 4 figure aftermarket kits, but a lot of people seemed to have just upgraded the discs and pads for something a bit more aggressive. (EBC/Black Diamond etc)
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    What A3 Do you have mate?
    Maybe just upgrade the pads and discs all round?
    Jason
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by Jason_letts
    Jason
    it's a 2002 TDI PD 130 (fwd) re-mapped to 162bhp
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    You can pick up a decent set of MK4 R32 front brakes for around the same as them 312mm.
    332mm by 34mm discs and twin piston calipers.
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    where from?
    Smart Roadster 03
    Ford Sportka 05
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Ebay or uk-mkiv.I sold a set not too long ago for 200.
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    You can just get caliper carriers from vw or audi (I'll post the part number asap) that move your calipers out to accept the TT discs. Then buy a set of Zimmerman (or similar) TT discs and uprate your pads (I'm using Pagid fast road and would recomend them).
    You will however need 17" wheels or be willing to grind down your calipers a little to give standard 16" rims clearance.
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    Jun 2006
    831
    I'm running the 312mm S3/TT setup on my 192bhp A3 with OE VAG Pads and Discs. All the stopping power i could ever need, not as fade resistant as a twin-pot setup but i don't drive in a manor that requires repeated heavy braking so it doesn't bother me.
    Difference from 288mm setup is significant. With my remap they were woefully inadequate, but i also blame the fluid. I swapped to Motul RBF 600 Dot4 Race Fluid when i changed to the TT setup and i think this has helped considerably.
    Second biggest improvement i made to braking was fitting Eibach Shock and H & R Springs; the car is much more stable and doesn't nose dive under braking like before. This is a good thing as prevents the back end getting 'twitchy'.
    Jul 2006
    London
    385
    i got mine from here: http://www.golfturbo.com/ and another set for a mate.
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    Skanky I know your local to me whereabouts did you get them fitted and how much? Need brake discs and pads asap
    Smart Roadster 03
    Ford Sportka 05
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Thanks for the information guys, i think i'll go for the TT/S3 brake conversion when i've got some spare time, i've got 17" S3 alloys on at the moment so they should just fit on (i hope)
    Jun 2006
    831
    Quote Originally Posted by MikeA3
    They'll fit with room to spare
    Same Caliper as the 288mm setup, just spaced out by the carrier to accomadate the larger disc. I'm pretty sure they'd fit behind the 16" OE alloys too.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by Tallpaul
    might be a daft question but from my understanding of the brake setup all i'd need is the new discs and pads?
    Jun 2006
    831
    And the Caliper Carriers to physically move the calipers further from the hub to accomadate the disc...
    Discs about 80, Caliper Carriers about 140... But you can get them from a scrappie
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    If your doing it on the 16's you will need to grind a little off the calipers (I know this from doing it on my mates Bora) but if your sticking with your 17's you'll have no problems
    Dec 2006
    7
    I can confirm that the 312mm set up go under OEM 16" wheels no problem, they fill the inner rim though!!!
    '02 Golf GTI Turbo
    Xenons | Santas | Milltek | .:R32 Front Bumper | Pentagon Tints | Forge DV | K&N | TT Pedals | W8 Light | '03 Wipers | US Spec Rear Clusters | Custom Rear Wiper | foxy mods | H&R -35mm & More!
    Dec 2006
    7
    Quote Originally Posted by TRS1
    If they are OEM wheels you won't need to grind any off as they are designed with a slight lip oin the inside to give the adequate clearance. The V6 4mo golf's and Bora's came with this set up as standard.
    '02 Golf GTI Turbo
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    His Bora had 16" bbs split rims that came on when he purchased it new.
    We had to grind a little off. I'm unsure why then if your saying they fit.
    Suck it and see!
    Dec 2006
    7
    Never come across an OEM set that wouldn't clear but there is always the 1st time and I stand corrected!
    '02 Golf GTI Turbo
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    Do you do this mod a lot then matey?
    Dec 2006
    7
    I don't fit them myself but lots of people who know me have!
    '02 Golf GTI Turbo
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    Just re-read my last post - it wasn't meant to sound like I was questioning you! You just seem to know what your talking about.
    Maybe we had an odd set of calipers or something?!
    TRS1's Avatar
    Topper Harley
    Nov 2006
    Button Moon
    328
    May 2003
    Reading
    705
    I bought the caliper carriers from uk-mkivs for £100 and then got some new discs and fitted them myself in a couple of hours. Worthwhile upgrade if you ask me for the price.
  28. #27
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by j4jon
    I bought the caliper carriers from uk-mkivs for 100 and then got some new discs and fitted them myself in a couple of hours. Worthwhile upgrade if you ask me for the price.
    Did you fit OEM standard pads and discs or aftermarket ones?
    also - has anyone done the rear brakes as well - this would have to wait for a bit but is it worth doing?
    thanks again
    mike
