AH FabricationsJMB Retrofits
Results 1 to 12 of 12
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    Window Jammed Please Help!
    Hi guys got a slight problem my drivers window is stuck all the way down i can get it to move but not very much!
    Any idea what it would be? Motor? Dont know if i should take it to audi?
    Need it done asap incase it bloody rains!
    any help apreiciated,
    Jason
    P.S im in Surrey...
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    markyp2002's Avatar
    Oct 2006
    Burntwood
    301
    its either the runner motor or the runner itself, possibly an easy fix but i would suggest gettin it done asap!
    A4 B7 2.0 TDi S-Line Special Edition Gloss Red, BOSE, 18" Black RS4s, Black / Grey Leather, Sat Nav
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Yeah thanks for the speedy reply mate im goign to have to take a half day at work and try get it sorted!
    Should i call some-one out mobile or just take it to my local audi?
    Audi im thinking ???
    Jason
    A3 1.8TS
    markyp2002's Avatar
    Oct 2006
    Burntwood
    301
    well audi quoted me 220 to change the dv with a factory OE dv to reset the engine light.
    so if you have got a VAG specialist near you, or a decent garage/mobiler then just give them a call, its only a window motor/rail not worth forking out at audi for it.
    Pete69zx
    I have the same problem with my driverside window.
    But in my case, it only sometimes happens that it wont close.
    It's as if when the window is on its way up it hits a restriction & starts to go all the way back down again.
    I have managed to cope with this for a few months now (by not using the window when i can helps).
    I have found a little trick... when the window is on its way back up, be standing outside of the car and clasp the window with both hands (if possible). One hand etiher side of the glass. Then as its on its way back up use a little force to keep it on its way travelling upwards. I tehn have to pull the part of the window nearest to the B pillar to make the fit better of i c feel/hear the air outside when the car is in motion.
    Wish i could afford to get mine sorted out, but funds are tight at the moment.
    Is it easy enough to fix myself does anyone know?
    Cheers.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I bet you this is what it is. http://www.piglet-net.net/tech/cars/a3-window.html
    Very useful link on exactly what to do. The part costs about 2.50, but it will take you a couple of hours to fit it as you have to take the door to bits and remove the door subframe.
    Exactly the same thing happened to me in a service station in the south of France just as I was beginning the 700 mile trip home. Fortunately with brute force of 3 people's fingers on the glass, we managed to close the window - otherwise my back seat passenger would have got very, very cold!
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Quote Originally Posted by Jason_letts
    P.S im in Surrey...
    I'm in Surrey to so could help out when you get the replacement clip as I've done this before.
    In the meantime, what you need to do is get some friends, as Pete says, to grab the glass as it sticks out a few inches and before it winds back down. As I said, it took 3 of us, but a bit of brute force will close it - at least that solves the rain problem.
    Jason
    rodenal's Avatar
    Oct 2006
    1,982
    Thats strange my sunroof sometimes wont shut if its been fully opened, i just assumed the motor was goosed could it be something else?
    It slows right down, stutters, stops then opens itself up again unless u grab it and give it a good proper pull.
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    smitch's Avatar
    Sep 2006
    1,585
    Give A H Autos in Guildford a buzz, they're VW Audi specialists and very reasonable.
    01483 303942.
    S4.
    Jun 2006
    712
    this is a relatively easy fix, it was covered a while ago. you just need 2 new clips per side
    DreA3Turbo's Avatar
    DreA3Turbo
    Aug 2003
    25
    Quote Originally Posted by jcs356
    Perfectly timed! My drivers side (of all the windows to go!) has decided that its not playing the game now......had to happen whilst raining at KFC didnt it! LOL....
    Will be giving this guide a go!
    Cheers!
    Definition of a Paradox : Your Damned if you do and your Damned if you dont......So Just DO IT!!!
    A3 1.8TS | APR modchip | Forge DV | S3 Roof Spoiler | 40mm Drop | 19" B7 RS4's | S3 Black Interior | 12" JL Audio W3 | CrossFire Amp | Full C-Code | & the eyes of an Angel....
    Dec 2006
    190
    Windows
    Have a look on the FAQs on this site there is an article about this on there
