Head light switch illumination
adamgroves
North Yorks - Northallerton
Should the three light symbols above the headlight switch be illuminated, ie. off, sidelights and dipped cos mine aren't, just wondered if the bulb has gone behind and if so how do you get to it?
Yes, they should be illuminated. To extract the switch, you push it in and turn it (can't remember if it is clockwise or anti clockwise), and then pull the whole switch unit out of the dash. I don't think there is a separate bulb from memory.
with the dial set to off, push it in and turn clockwise at the same time - it will then release (by the time it gets to side lide light setting)
