Chris NottJMB Retrofits
    Sep 2006
    Sunny Suffolk
    552
    Headlamp - Can it be repaired?
    Hi,
    I have just noticed that my passenger side headlamp is missing an adjuster
    The parts cirlced below are not there, and just a shaft is left where the toothed wheel should be, meaning the the lights wobble when going over bumps etc.
    Is it possible to attach another adjuster? Or do I need a whole new headlamp?
    If the later, has anyone got one going spare?
    Cheers,
    ICE
    PaulS3's Avatar
    UK
    1,003
    gear wheels are pressed on in an automatic press station.
    even if you had the two gear wheels, its unlikely you would get the larger one onto the stud without breaking the headlight further.
    Audi S3 Quattro Black Edition.
    Sep 2006
    Sunny Suffolk
    552
    Does any one know the part number for a passenger side facelift headlamp?
    I thought the lights were a little low...
    Cheers,
    ICE
    Sep 2006
    Sunny Suffolk
    552
    UPDATE:
    Have used a couple of zip ties to hold the stud in position - so far so good.
    Would still like to know the part number for a passenger side facelift headlamp
    Cheers,
    ICE
