Sky InsuranceVolks Autos
Results 1 to 9 of 9
    mad max's Avatar
    sixth gear
    Jul 2006
    beyond the thunder dome
    335
    oil pump failure early warnings ?
    have owned two cars now with the same 1.8t engine namely 225 tt and now my s3 so i know they can sound noisy on initial start up because of hydraulic tappets.i have noticed of late it is taking several minutes or untill the engine has completely warmed up however for this noise to subside.my old tt was never this noisy is this because they had a non return valve.do you guys think this is an early sign of oil pump feed pipe blockage.not getting any oil warning signs coming up.would an oil pressure test show up any potential problems ? would appreciate any advice
    S3 TUNED AT MRC
    mad max's Avatar
    sixth gear
    Jul 2006
    335
    come on lads someone must have some knowledge of this
    S3 TUNED AT MRC
    Jan 2005
    Norfolk
    304
    I think an oil pressure light would trigure if the pump was on its way out.....
    more likely (perhaps) is that the hydraulic lifters are full of crap and oil isn't able to flow in as freely as it once could > hence no lubrication > hence the increased noise as it's metal-on-metal
    this isn't a good thing in itself - I think audi say up to 2 minutes is normal and anything more than that requires replacement. btw adding an engine flush to the oil doesn't seem to work either (and isn't recomended by audi!). however, you could try it if you're close to an oil change - apparently forte brand is the best.
    mad max's Avatar
    sixth gear
    Jul 2006
    335
    i have read about a fault with the strainer on the pump feed pipe.the gauze filter is quite fine and can become blocked and can starve the pump of oil .the pressure remains stable,its just that not enough oil is being supplied to the various components.if the camchain variator is starved of oil for any length of time the rattle can become permanent.before any of this happens would i get any early indications such as exhaust smoking or oil light on the dash.
    anyone had anything similar on their car
    S3 TUNED AT MRC
    Aug 2004
    526
    Quote Originally Posted by VAGMAN1
    What are the possible consequences of this as I can here the lifters I think (car has covered 93K).
    Cheers,
    B.
    mad max's Avatar
    sixth gear
    Jul 2006
    335
    it can remain undetected for some time causing damage to the turbo and the cam timing variator before any audible warning is heard or the oil pressure light comes on.utimately this damage would affect performance as the valve timing is affected.
    can anyone add to this or has anyone got first hand knowledge of this problem ?
    S3 TUNED AT MRC
    Feb 2005
    Scotland
    13
    I've read about this somewhere,I've tried searching ukmkiv,and votex,but i can't find any mention of it.It might have been the guy who writes the technical colum,in Audi driver who mentioned it,but I've definetly read the same thing as you Max.If you catch it early,take the sump off and clean it,and all should be well,finger's crossed.
    Gar
    mad max's Avatar
    sixth gear
    Jul 2006
    335
    Quote Originally Posted by bantam1
    Cheers,
    B.
    not shirt lifters i hope or we are in trouble
    sorry couldnt resist it
    S3 TUNED AT MRC
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    oil pump will kill the engine almost instantly no warning.
    just a little a6
