Volks AutosMonster Motorsport
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    How HIDs self level
    Could anyone supply me with a picture of how the self leveling is achieved on facelift (2001-2003) HID headlamps? I've tried looking at the ETKA diagram and i can't see any sort of motor which would do this so i was wondering how it works. Cheers for any help
    Ross
    PaulS3's Avatar
    UK
    988
    no pictures, but the jist of how it works....
    1 x motor in each headlight.
    Sensors on the suspension feed back to ecu(s) that then tell the motor which way to move +/- from its home position.
    hence why to manually adjust the beam, the xenons must be "parked" in a diagnostic home position, with dealer or vag com equipment, before manual adjustments.
    Motors are small units, which can be wired with external plug, or some wired internally. I cant remember which the S3 has, never had to look that close.
    Audi S3 Quattro Black Edition.
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    The motor plug connection is on the inside edge of the rear of the lamp. It's the only one that looks like it doesn't connect to a bulb.
    I've disconnected my nearside motor as the beam kept dropping to the floor. I'll have a crack at fixing it when the weather's a bit warmer.
    cha1n's Avatar
    Jan 2006
    Bristol
    101
    Well i'm going to be retro fitting parts from these headlights http://www.hella.com/produktion/Hell.../Double_HL.jsp I'm not a fan of the look of these headlamps so i'll be stripping down all of the components and retrofitting them into my facelift lamps, i'm hoping as standard equipment is hella that sizes will be the same but i'll soon find out. I've also got the headlamp washers to fit, but hopefully i'll end up with a full road legal set of xenons for half the price. I'll post pictures of progress when i receive the lights.
    Ross
    SwedeS3's Avatar
    Mar 2003
    Lincoln
    73
    here you go cha1n, i have taken a photo of mine while i have them apart, if you need any other photo's give me a shout in the next hour before i put them back together again
    Swede
    Ebony Black 2001 Facelift S3 | BOSE | REVO Stage 1 | Porsche GT3 Brakes | Tcarbon Intercooler | FK Wheel spacers | Painted Headlights
