You're not getting much luck are you? Is your indicator still inside of your wing and i assume the wing mirror once worked, and that you didn't buy the car with the wing mirror not working?
When you bought the car, did the wing mirror work then?
Basically i'm trying to derive whether you have done something recently to the circuitry to cause the fault, or if you bought the car with the fault in place.
