Badger5Volks Autos
Results 1 to 7 of 7
    Pete69zx
    rear wiper wont work...
    Why wont my rear wiper work?
    Admittedly ever since i have owned the car, the rear wiper has never worked.
    Is there a fix to this, is it a common issue with the A3?
    Maybee its the fuse, where is the fuse boix located & which fuse is it i need to check?
    Sorry for all the questions, just now the bad weather has come im a bit stressed that i cant see out the back window!
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    the fuse box is on the side of the dashboard, the place where you wouldn't normally see when the door is closed. on my RHD car it's on the driver side, so should be in yours too.(drivers side i mean)
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
    Jul 2005
    2,488
    it either going to be the fuse, or knackered motor.
    the motors on these are prone to rusting and seizing due to the pipe carrying the washer fluid through the wiper arm spindle breaking.
    Pete69zx
    Since its now dark outside, i will investigate tomorrow.
    Is the motor serviceable? Or could it require a new one if that is the problem?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,296
    If the motor has gone then it's easier just to get a new one from the stealership or a second hand one from the scrappers. Take the tailgate inner trim off and check everything is connected properly then also check the fuse. If both are ok you know the motor has given up the chase... RIP!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    mykaloon's Avatar
    Jul 2006
    Angus, UK
    42
    I recently had the same problem with my rear wiper on my A4 Avant. It was the motor - managed to get one off a breaker advertising through ebay for something like 35 (its the same motor used for the A3 and the A4 Avant). If I remember correctly, they're something like 65-70 new from local stealer.
    Mykaloon
    2007 Audi A4 Avant 2.0tdi (170) Sline - Brilliant Black
    1998 Audi A4 Avant 1.8
    Sep 2006
    Chester
    71
    Is this the same rear wiper problem the mk4 Golf has? If so it might be reparable in a similar way to this:
    http://www.golfmk4.co.uk/rear_screen_washer_repair.htm
    http://www.golfmk4.co.uk/wiper_motor...ion_repair.htm
    My Golf had a rear wiper that started whenever I turned on the ignition and I found the leaking washer water had corroded the controller PCB.
