Results 1 to 7 of 7
    Oct 2006
    91
    How do i remove my stereo?
    I've got a hands free kit in my car thats been slotted up the side of the head unit, and want to remove that part of it, becasue it still hooks up with blue tooth anyway. so i'll need to remove my stereo to do it.
    does anyone have any pics or know of a walk through for taking out the stereo?
    Herby1's Avatar
    VAG All the way
    Oct 2006
    303
    is it standard or an aftermarket unit?
    Herby1's Avatar
    VAG All the way
    Oct 2006
    303
    if it is standard you need a pair of these....click on link - http://cgi.ebay.co.uk/CD-RADIO-REMOV...QQcmdZViewItem
    with these you simply slot in at the bottom of the unit....you will see some smaill slots push them in the right way all the way then simply pull it out!
    if it is an aftermarket stereo you need to find out what model stereo it is and either purchase the keys from ebay or do what i used to do......use some cable ties down the side of the unit!!!!
    Hope this helps!
    Jun 2003
    World of my own
    9,813
    "with these you simply slot in at the bottom of the unit....then simply pull it out!"
    That's the theory. Just be very careful as it is really easy to knacker the clips holding the unit in and then you'll have to take the front off the HU or remove half the dash.
    You put the keys into the slots with the angled sides facing inwards (towards each other). You should feel some slight resistance as the keys engage and start to release the sprung loaded clips. If you can't feel anything then it's likely that the clips are broken or bent. Try pushing the HU into the dash as this releases any pressure on them.
    If you get to the point where you want to use a chainsaw on the bloody thing then get out of the car and take a break.
    If it is well & truly wedged in there then there is an alternative. You can pry the whole of the front panel off the HU which will then give you access to the clips. To do this you need to tape up the facia so you don't scratch it then use a thing flat paint scraper or similar and prise up the bottom of the HU front panel. It is only held to the HU by 4 plastic clips (2 top, 2 bottom). When you have the bottom released then do the same for the top and then the whole front panel comes out. With the front panel removed don't try to take all the screws out of the HU behind as there are no more bits that can be removed from this position.
    With some small long nozed pliers you should be able to release the HU now. The front panel just clips back on again.
    Hopefully you won't need the above and it will just slide out effortlessly but many people have had real problems with this simple task (me included) and it's a helluva lot easier to do it right first time.
    Herby1's Avatar
    VAG All the way
    Oct 2006
    303
    much better step by step....cheers mate, didnt have much time to write all that...at work.....but yep that is exactly how you do it...
    nice one andymac!!!
    Oct 2006
    91
    Quote Originally Posted by AndyMac
    Thanks that's really helpful.
    Oct 2006
    Newcastle
    24
    Ive had a problem with this too, the right key clicks in fine, but the left one doesnt click in at all. Looks like its a facia removal for me
