Chris NottEM Tuning
    Jun 2006
    298
    MAF logging in vag-com
    Can anyone tell me how I can log my MAF in the shareware version of vagcom?
    I think it was TallPaul who said it can be done, and that you are only able to log the first 25 blocks but I can't see how to do this.
    Can someone give me some nice instructions? Only just got vagcom, so quite a noobee to it.
    Andy
    Oct 2006
    86
    Go to Engine - 01
    Then Measuring blocks -
    Then go to group 002 and press Go!
    You will see the MAF reading in g/s in block 3 or 4 not sure which.
    If you want to log this data go to [log!] and do a run from 2000-6500 in 4th gear. foot to the floor! ( you will be going v quick by 6500 rpm so make sure you do this on a private road
    Jun 2006
    298
    Thanks for that mate, got it working, did a run, you were right - V V quick!! -so after I'd done it, and slowed down to a suitable speed, I clicked Done, Go Back. And the log wasn't in the logs folder!
    But I couldn't see anywhere to save the log, I assumed it would know that you wanted to look at the log and save it automatically
    How do you save the data so you can manipulate it later?
    Andy
    Oct 2006
    86
    you need to click "Done, Close" after the run and it will be saved in \program files\vag com\logs\xxxxxxx.csv
