Chris NottAH Fabrications
Results 1 to 8 of 8
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    Exhaust Manifold Problems S3
    Just wondering if anyone else has problems with one of the 3 bolts that join the exhaust manifold to the turbo coming loose and falling out causing it to 'blow'
    I have to keep replacing the bolt and washers every 2-3 weeks
    any ideas how i can stop this happening? not very safe if the bolt should flick up and hit someones car / windscreen
    ash
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Never heard of that happening, should be fine if tightened to the correct torque, however if not why not put some locktight on it or go the motorsport route and wirelock the bolt in place.
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    tried threadlock and it didnt work at all, i imagine the heat would just melt it
    my dad suggested to wire-it-in but its so tight down there i just cant see it happening! Im running out of bolts and split washers!!!
    do you think i should try a genuine audi bolt n see if it makes any diference?
    thanks
    Ash
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    There are lots of different types of thread lock designed to work in different applications, you should be able to get one that can handle the heat.
    What nuts have you been using?
    If i remember rightly the genuine VAG bolts are locking nuts with a slightly oval'd hole, if you are not using these that may explain why they are coming undone
    Sold - 2002 S3
    Jul 2005
    2,488
    definitely use VAG bolts!!
    unless you use proper bolts, theres the chance that the difference in metals will cause a difference in size expansion due to the heat. Also you need to make sure the thread depth is sufficient to stop them just dropping out (however unlikely that sounds!).
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    you need to use copper bolts which have the slit in the side....They lock down and should not come undone!
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    ah great thanks!
    are the genuine bolts copper??
    i dont think you need nuts because the hole is threaded??
    thanks for the help!
    ash
    ...Watching you!
    Earlsfield, London
    5,087
    Hmm... i honestly can;t remember.
