Chris NottAH Fabrications
Results 1 to 8 of 8
    Nov 2006
    10
    Dog bone bushes for TDi
    I am looking at fitting the dog bone bushes on my TDi A3. However some have told me that the design of aftermarket bushes is so hard that the car vibrates inside?
    has anybody else been told this or just a rumour? I really need to know before buying the bushes kit.
    Thanks in advance
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    I have them fitted to my S3 and yes there is a slight bit of vibration when pulling away but not when idling or cruising....but mines have now settled down and it is no longer noticable.
    Buy them for what they cost, if you don't like them then revert back to standard. It only takes 10mins to change them.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    I've got the even harder ones made by ECS on my car (and all three parts) and there is more vibration however I don't find it annoying as it's only really at pulling away / very low revs it makes any difference, however the changes to the gear change etc are worth any down side from the vibrations.
    Forgot to add, in my opinion most of the people that complain about the bushes didn't fit them right as you really need new bolts and they need to be set to the correct torque.
    Nov 2006
    10
    Thanks for the info so far. I have been told the situation is different with the TDi engine. More vibration?
    Surely someone has had something work for a TDi as there are loads of you out there. I think LOL
    Mo-S3's Avatar
    North West
    706
    Yes lots of vibration!! Sell it an get an S3! lol just kidding. Tdi engines do vibrate more hence not to go for a too hard bush. Have you torqued them up correctly?
    Any one know the correct torque settings for the bolts?
    Jun 2004
    Crowthorne, England
    2,512
    I can find them for you on saturday if you still need to know, it's pretty low torque because you're squashing the bushes as you tighten the bolts if that makes sense.
    Nov 2006
    10
    Ah, so the petrol engine is different to the diesel for the vibration!
    So is there maybe a dog bone bush kit for TDi ?
    Mo-S3's Avatar
    North West
    706
    Yes there is a decent dog bone kit for the TDi. I personally dont recommend you go for the Powerflex ones as they are like a solid block of plastic and are known to be too hard.
    I have got SuperPro ones fitted to mine and you can choose the various grades of softness for dogbone on the TDi.
    I have the intermidiate( fast road/street) one fitted to my S3 and suggest you go for the '70' grade if you have a soot chucker.
    If you need further help let me know.
    Anyone got the correct torque figures for the dog bone mount ?
