Volks AutosEM Tuning
Results 1 to 10 of 10
Thread: S3 DIS fault
    Mar 2006
    Chester
    79
    S3 DIS fault
    Hi, I’m thinking of buying an S3 (facelift), but the dash display seems to be faulty – it has lines going through it. Is this common and does anyone know what causes it?
    Is it something that can be fixed, or would it be a case of getting a new dash pod from a breaker and then getting it reset to the correct mileage?
    Cheers guys
    Jun 2003
    World of my own
    9,813
    Yes very common, either fading or lines across it. Don't think it can be fixed, so yes new instrument cluster unfortunately, don't know if you can just swap them, or if you'd need VAGCOM. The mileage is stored in the ECU IIRC so that shouldn't be a problem.
    Mar 2006
    Chester
    79
    Cheers, so it should definitely just be a case of putting in a new cluster, and then possibly getting an Audi specialist to set it up using VAGCOM?
    Mar 2006
    Chester
    79
    Oh - one more question... will any replacement S3 cluster fit or did they change for the facelift? Cheers
    monkeytrousers's Avatar
    Jul 2004
    East Sussex
    372
    I think they did change ... some of the early S3s have analogue clocks. Not sure if directly related to facelift cars though.
    Audi A4 3.0 TDI Quattro 2008 - Ice Silver
    JUST GONE: BMW 330i M Sport Saloon 2006 - Le Mans Blue
    GONE BUT NOT FORGOTTEN: Audi S3 Quattro 2002 - AMD stage 1 - 261BHP - MTM clutch - Brilliant Black
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Monkey trousers is spot on, they changed to digital clock before the facelift, my car is 2000 and it's got a digital clock but some earlier cars do not. Not sure if anything other than the badges changed on the facelift, there could have been more features for the CAN-BUS system on later cars but not 100% sure on that.
    Mar 2006
    Chester
    79
    I've just read this which seems to suggest that it may not be possible to plug in a new cluster and have it 'coded' in to the car.... arghhh confused now!
    Lcd display faulty
    larsmate's Avatar
    Apr 2004
    111
    I think there are four versions - prefacelift analogue clock, prefacelift digital clock, facelift (pre 165kw version) and facelift (165kw version). You will need the correct one as there are differences with CAN-BUS compatibility. Once you have the correct one, second hand or new, you will have to get the dealer to install and code to your car. You do need them to recode cluster, ecu and keys, all three together.
    Black S3 | MY09 | APR 3.1 Stage 2+ | RNS-E Mk2 | Tints | Titaniums | APR DP | APR HPFP | WALK | H&R SPRINGS | Lamin-X | BlueVAG VAG-Check |
    Jul 2005
    2,488
    you cannot change the milage on a cluster that has been previously installed. The milage and IMMO codes are stored in the ECU AND the Dashpod.
    The cluster only allows ONE milage change, and a FORWARD only change too. For most clusters, this would have been changed when installed/replaced - so you have no changes left.
    Mar 2006
    Chester
    79
    Well, the need for this has gone now..... although it was claimed to have a clear HPI, I did my own anyway. HPI showed that the 62k mile 2001 FSH, 1 previous owner S3 had actually done 62k in 2002 when it was a year old, and was now about 120k! B*stards!
