Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    Nov 2006
    9
    Help needed please!!
    Hi, I have just bought a 2000 a3 1.8 turbo. I am having a problem when driving over 50. When I change gear and accelerate there is a severe delay (the car physicly slows down/judders) for about 2 seconds, and then it's fine until I accelerate hard or change gear again.
    The car is completely standard, has done 66000 miles and has just had a service and cam belt.
    I would be greatful for any help/info you have,
    Pete
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    That would be the MAF(airflow) sensor then, yours for £80 exchanging your old unit from any VAG stealership, a simple 10 minute job, so save yourself the labour.
    You've got to have a laugh!
    Nov 2006
    9
    Thanks for your help mate. Much appreciated!!
    L1 HCS's Avatar
    Candy Tetris Champion, Mahjong Champion, Magic Ball Champion
    Oct 2006
    cymru
    4,597
    Is the MAF another name for the Lambda sensor? or is it something completely different. My car had the VAG com test... Lambda sensor wasn't working properly.. got it changed.. but its still not 100% still juddering a bit..
    "Swallow your pride occasionally, it's not fattening." - Frank Tyger
    "Avoid making irrevocable decisions while tired or hungry." - Robert Heinlein
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Just to double check that it's the MAF sensor, try unplugging the connector for the MAF right after the airbox in the engine bay, and take the car out for a spin, it will be running lower on power, but the power hesitance should disappear. If it's still there, then it could be something else...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,833
    Quote Originally Posted by Ming Blue
    No, the MAF sensor is situated after the airbox, where as the lambda sensors is situated after the turbo near the cats on the exhaust.
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    I second what Jojo says about the MAF. Just make sure you unplug it with the ignition switched off, to be on the safe side.
    Just do it to diagnose the problem. Leaving it unplugged isn't a long term cure, even if it seems to run better.
    L1 HCS's Avatar
    Oct 2006
    cymru
    4,597
    Thanks guys!
