JMB RetrofitsAH Fabrications
Results 1 to 14 of 14
Thread: S3 rev hang-up
    Jul 2003
    Berkshire, the Royal County
    S3 rev hang-up
    Problem : Accelerate briskly, change up 1st to 2nd, revs hang or increase! 2nd to 3rd revs hang or increase again, same 3rd to 4th, and this is with full lift-off the loud pedal! Makes you feel like a learner but I've been scorching around in cars and on bikes for 40 years,
    don't label me an old f*rt, look at the ages of the best sports/endurance racers (age, not size, of the b*lls counts).
    Back to the issue : the only way to stop the motor reving on as you change up is to take a full second for each gear change to allow the revs to drop a little, defeating the object of a brisk car.
    My local dealer claims 'they all do that sir to keep the turbo spinning'. Well the few I tried before buying didn't, nor did mine 'til the last service.
    When I'm a biker and I ease the throttle a bit to sync the revs on an up change I expect (and get!) the engine to respond.
    Is my S3, Jan'01, a freak? or do any of you guys also suffer this problem?
    mramage's Avatar
    Scotland
    514
    Re: S3 rev hang-up
    Erm, that does't sound right. The revs certainly drop off on mine between changes. Get the dealer to take you out in another car or get a tech to come out with you and demonstrate the problem. Don't let them off with it [img]/ubbthreads/images/graemlins/smile.gif[/img]
    I had a car that used to do that and it got the lambda sensor changed. Not saying it's that, but it certainly doesn't sound right.
    Your car wouldn't be purple by any chance? Sure I saw a purple S3 with a similar reg the other day, meant to post on spotters forum.
    Jun 2003
    Portimao Portugal
    83
    Re: S3 rev hang-up
    mine does the same but only if i change up on full throttle at about 4k revs if i take it to 5k plus it does not do it!! [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Jun 2003
    133
    Re: S3 rev hang-up
    There's a switch on the clutch or the accelorator pedal cant remember which one, it can stick and the revs will hold after life off. Have a search of the forum i have read about it before not sure which forum i read about it on might have been tt forum worth a look.
    Good luck
    Bucks
    1,038
    Re: S3 rev hang-up
    My rev's hang for a bit - drive along and put your foot on the clutch and they just hover for a noticeable time before dropping.
    I figured it was just a (bad) characteristic of the car!
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Re: S3 rev hang-up
    Perhaps you guys need a throttle body re-alignment. It can be done via a VAG COM IIRC.
    AL
    Sep 2003
    Manchester
    340
    Re: S3 rev hang-up
    mine doesn't do that, full throtle, press clutch and come off the gas, revs drop, change gear, gas....and away I go [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    Jul 2003
    Essex
    358
    Re: S3 rev hang-up
    Mine does the same as your's Audi Girl. Like you say it depends on whether the car is in drive or not, stationary out of gear its no problem , but in gear you notice the revs don't drop off as fast..
    verdict : crap
    Bucks
    1,038
    Re: S3 rev hang-up
    Out of gear it's the same - like when changing gear :-S
    Jul 2003
    Essex
    358
    Re: S3 rev hang-up
    Nah i only notice this when i'm stationary and revving the engine in frustration (due to excessive traffic in London)
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: S3 rev hang-up
    My A3 does exactly the same thing... was wondering if it was normal just the other day!
    Rich
    Nov 2003
    Gloucester, England
    50
    Re: S3 rev hang-up
    Has anyone who has this problem looked into it anymore or fould the fault or cure ?
    bjacks's Avatar
    78
    Re: S3 rev hang-up
    MAF replacement helped, although that's not why I replaced my MAF - it was an added bonus [img]/ubbthreads/images/graemlins/grin.gif[/img]
    At over 200 a pop, not something to be tried without proper diagnosis, or swap the sensor over with a known good one.
    Ben
    Nov 2003
    Gloucester, England
    50
    Re: S3 rev hang-up
    I have benn to see a freind of mine and he is a ex Audi tech, he says that the flap in the throttle housing gets a bit of gunk around the edges and this can cause the problems so I am going to remove it when i get a chance and then he said he would set it up on vag-com for me.
