Volks AutosAH Fabrications
    KEF A3 20V T's Avatar
    Turbo's Rule
    Sep 2006
    Whitby
    198
    k04-023 turbo only!!??
    hi was wondering, i have a k04-023 turbo sat in my bed room gathering dust was wondering if i would be able to just fit that without injectors n maf?? would it work or not???
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    951
    Not a chance fuelling and airflow would be all over the place,at your own peril.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Jul 2005
    2,488
    would it? surely the boost would be monitored in the same was as before, just the wastegate would open earlier as the boost limit was reached earlier?
    i'm no expert any level on turbo's, but i'd expect it would work fine - you'd just be waste(gate)ing all that extra boost you could be using.
    A custom remap is the bare minimum for installation and seeing any benefit.
    Jun 2006
    831
    Is this a theoretical or practical question?
    I guess theoreticaly just changing the turbo would be OK at low-mid revs. I'm not sure the N75 would necasserily be OK on it's own under full load. You don't even want to risk running lean IMO.
    Practically you can't just bolt it on. Your mani, downpipe, oil/coolant lines and turbo intake pipe are all the wrong size/in the wrong place.
