Badger5AH Fabrications
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    Aerial base removal
    Quick question what is the easiest way to remove the base of the aerial from the roof. I know you can access part of it through the rear interior light, is it possible to remove it all through there or do i need to take the middle section of the roof lining down from just the rear between the c pillars.
    If i do need to take that down , how does it come apart ?
    do i need to take rear quarter covers off too?
    My reception is getting worse lately , and i believe the base section becomes porous over time and interfears with quality.
    Hope someone can shed a little light on the subjuct for me
    Neil
    Jun 2004
    Surrey
    595
    There is a PCB in the aerial base that you can get to from the interior light just pull the black cover off to see if it has any water damage.
    Unscrew the whip. Carefully lever the base up and then fold in back on intself ie up the air. You will need to protect paint when doing this and an extra pair of hands is a good idea to hold it while you use an adjustable spanner to undo the nut underneath.
    I changed mign to a shark fin but the seals on the original aerial were shot.
    sprout99's Avatar
    Jun 2006
    North East - Dodge city
    367
    Quote Originally Posted by steve1975l
    my aerial seal is cracking and aerial is split too.
    trying to put this off for now.
    2004 AUDI A3 S-LINE DSG TDi
    MAURITIUS BLUE
    2005 BMW 120d M Sport 163+
    BLACK SAPPHIRE
    Mar 2005
    Scotland
    91
    the wire that connects the aerial to the radio has a plug and socket about six inches down its length. this can also be disconnected if you need to.
    to do this, i opened the boot and removed some of the big rubber black seal and CAREFULLY pulled down the headliner from there. when you find the little plug/socket, there is a little arrow on it to show you what way to pull it apart.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    i removed the rear light switch panel, access is tight but it is possilbe managed to change mine fine. Infact PCB which is usually located in the aerial base now sits inside the car rather than out. Speak to VAG parts for details about £28 if i remember correctly.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
