JMB RetrofitsChris Nott
Results 1 to 10 of 10
    Mar 2005
    west midlands, england, uk
    14
    Electric Window Problem
    Hi all, my drivers side front window has stopped working (does not open or close) when depressing switch. All the other windows still work fine. Any ideas guys ? Car is Audi A3 2002 TDI
    JohnS3's Avatar
    Oct 2004
    3,021
    You didn't say if the motor is still running or not. There is a long thread on here about the clips which hold the window to the winder mechanism, they are quite prone to breaking. This might be your problem.
    Faulty S3 Electric Window Fix
    Mar 2005
    14
    Thanks John, i cant hear no motor running at all when pressing the button, like i said all others seem to be working fine but this is not doing anything. Does one motor control all the windows or do all have separate ones ?
    JohnS3's Avatar
    Oct 2004
    3,021
    Each window has it's own motor. I'm unsure if VAG-COM will show faults on the window motors, perhaps someone else will come along and confirm. Persoanlly I'd be tempted to take the door card off and check for live feeds to the motor. If you don't feel up to this then you could take it to a local dealer, but you'll pay for the privilege
    Sep 2005
    West Midlands, UK
    141
    I don't think VAG-COM will pull any codes for the windows. When I had mine apart the only code recorded was against the radio, which noticed the speaker was disconnected.
    Apr 2007
    31
    Has anyone fixed this problem?My window wont go down but i can hear a clicking noise from the motor anyone have any ideas on what it can be?
    Done a search on elictric window problems and most seem to about the window not closing which from what i read is the clips breaking so i'm sure it not them
    Dec 2006
    44
    Is the switch clicking or the motor, if its the switch then it could be worth having a look at the fuse for it!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    one course of action would be to remove the door panel and check voltage to the motor, if there is voltage there, then disconnect the motor from the mechanism and see if it runs.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Apr 2007
    31
    [quote=A4Quattro]one course of action would be to remove the door panel and check voltage to the motor, if there is voltage there, then disconnect the motor from the mechanism and see if it runs.[/quote
    I'm going to have the door panel off today so i'll try this.Already checked the fuse and it aint that
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    dont forget to get some spare retaining clips...
    Chris
    See my images @
