Monster MotorsportChris Nott
Results 1 to 15 of 15
    Pete69zx
    whats next to gain more power from AGU lump...?
    I have an AGU engined A3 1.8T
    It has somesort of remap fitted by a company that i forget the name of now (already done by previous owner).
    It has a Forge DV fitted (alteast i think its a Forge).
    It has a Miltek system (unsure if its just CAT back).
    I have been told by the previous owner that it is around 220BHP (cannot confirm this)
    Anyways, the car has ample power & is quite responsive.
    I just want to know what is next to up the power some more?
    Would i need to consider ways of cooling the intake temperature before i think about more power?
    The car just has the standard SMIC & all OEM pipework.
    Cheers, Pete.
    KEF A3 20V T's Avatar
    Turbo's Rule
    Sep 2006
    Whitby
    198
    I cannot see that pulling 220BHP. mine is pritty much the same and its pulling 195 ish!
    for any more power you need a bigger turbo, either:
    1. ko3s, 220 ish
    2. k04 hybrid 260 ish fits standard manifold but needs injectors etc..
    3. k04-023 270/280 need new exhaust manifold, injectors,maf etc,etc
    4. Garrett gt28, up to 300/330 need fcuking loads of stuff looking at 4K
    i am in the process of collecting all the gear for a K04-023, decent gain and all OEM S3 parts to upfit so should be reliabe. will be bout 1500 all fitted with custom remap
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Yeah, it won't be anywhere near 220. The next on your shopping list would be a bigger turbo for power but then that comes with having to change alot of other things.
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Pete69zx
    Thanks for the replys guys.
    Hey Kev, i see your not too far from me.
    What you upto tomorrow night, fancy meeting up to talk cars and stuff? :-)
    I have just finnished having my facelift headlights fitted & want to test em out in the dark, lol
    Pete.
    Turbo's Rule
    Sep 2006
    Whitby
    198
    yea rite you do! for a k04-023 u need:
    • injectors green top 440s if you use s3 ones u need spacers for rail +4 bar fpr
    • Bigger maf
    • tip
    • turbo and exhaust manifold off BAM engine
    • OEM cats or Race cat
    • 3" dp
    • FMIC
    Pete69zx
    Sounds expensive already! LOL
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    spray pattern is better of OEM s3 injectors would be best
    just a little a6
    Pete69zx
    so, could i just add some s3 injectors, and get the car RR'd?
    would that increase performance a little?
    tommo-turbo's Avatar
    Aug 2006
    164
    I think you'd have to increase the fuel pressure too with a fuel pressure regulator or an uprated pump. What type of fuel pump's do A/S3's use?
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    950
    Quote Originally Posted by Pete69zx
    No point unless your maxing out your standard ones,which i doubt you are,i'm not yet.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Turbo's Rule
    Sep 2006
    Whitby
    198
    Andy you know what hp the s3 injectors max out can they take up to 280 bhp? and do you need spacers to fit them into a AGU head
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    next for horse power IMO are
    k04 direct replacement
    s3 injectors with oem 4 bar fpr
    remap
    you don't need fuel pump the standard is sufficient for that
    optionally at the same time FMIC and samco tip for reliability
    the next stage would be big turbo which would need £4k
    just a little a6
    Turbo's Rule
    Sep 2006
    Whitby
    198
    av sorced a k04-023 turbo and manifold off a 2001 tt so just wondering what injectors to use< i thort bosch 44o's would be fine with 3 bar fpr! btut ppl say they have a crap spray pattern! is the a oem 4 bar fpr like? Part number??
    ANDYTQ's Avatar
    Oct 2003
    950
    Quote Originally Posted by KEF A3 20V T
    I have heard 440's are not ideal also ie spray pattern,i have also heard that there are some porsche ones that are better suited and i don't think they need spacers either.Theres a few peps on seatcupra.net running aggressive st2 lcr maps and seem to get 280 on standard injectors.Jabba recommended s3 /lcr injectors for ko4 hybrid,its harder to map with 440's apparently.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    If the remap is done correctly then you'll only need a 3 bar fpr.
    DPM Performance
    T: 01207 561606
