Monster MotorsportVolks Autos
Results 1 to 16 of 16
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    Next Mod for my 1.8 T??
    Hi there when i get my bonus want to spend it on my car as you do
    As im guessing you guys know more than me, so i cant make my mind up and thought id ask you!
    Im happy with my ICE changed my headunit and got a different Sub and amp, and got a cat back SS system. Other than that all ive got is a set of 18's on standard suspension which has done 75k.
    So im thinking coilovers or remap what you think?
    Jason
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    Both a good choice! Which first though?!
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Timbo's Avatar
    Slowest car ever round the Top Gear track?!?
    Dec 2004
    Surrey
    275
    If you get the remap you'll want the suspension done straight away. If it's done 75K it'll be well past its prime anyway.
    FWIW when I changed the suspension on mine it made negligable difference to the insurance, whereas the remap made quite a bit of difference.
    1997 1.8T || AmD Stage 1 || Eibach springs || Bilstein shocks || EBC Brakes - Gone!
    2006 Nissan 350z GT
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Ok so your saying coilovers first?
    If so which ones so many to choose from range from 300- to over 1k.
    Im not bothered how hard the ride is i want more performance than comfort.
    Jason
    A3 1.8TS
    Jun 2006
    831
    Depends how much dosh you've got...
    REVO 400
    Eibach Shocks/H & R Springs plus fitting and 4 wheel alignment and the bushes that WILL be knackered 700
    I got REVO first and drove with everything else stock for 3 months. It was fine really but the extra power encourages you to push things a little further and that's when you discover the worn suspension and puney/fade prone brakes aren't up to it.
    For 250 the upgrade to 312mm brakes is an essential too IMO.
    Really good tyres are important too... Goodyear F1's, Toyo Proxes, Michelin Pilot Sport etc etc
    People rave about the ARB's too, but my shock were more urgent than them, although if i ever have the spare cash i'd do them too.
    All things considered i'd still get the remap first. Nothing else will make you grin as much.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    DPM Performance
    T: 01207 561606
    Timbo's Avatar
    Dec 2004
    Surrey
    275
    Quote Originally Posted by Tallpaul
    ...the extra power encourages you to push things a little further and that's when you discover the worn suspension and puney/fade prone brakes aren't up to it.
    Spot on - the remap makes the most difference but will highlight other things that will need doing (like worn out suspension).
    2006 Nissan 350z GT
    Jun 2006
    831
    Be sensible, fully adjustable H & R coilovers are way over the top for the potential power and probable use of a '98 1.8T.
    You don't need to spend anything like that to get great stability out of your A3.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I spent £515 on some FK Koenigsports, which are height and damping adjustable. The ride is pretty stiff, even on the softest setting, but they improve the handling no end, ride is compromised, as it always is with coilovers, but I personally wouldn't spend any more than £500 on new suspension.
    <Insert meaningless geeky specs here>
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Yeh i see what your saying so what coilovers would you recommend want a nice low drop as im running 18's under my arches.
    Still cant make my mind up Coilovers or Remap,
    I also need my cambelt service doing water-pump etc so ideally id want it all done at the same place has any-one been to quattronics for a remap as AMD cant fit me in for the service too at the moment.
    Jason
    A3 1.8TS
    Jun 2006
    831
    Quote Originally Posted by Jason_letts
    Jason
    If you want it to look lowered i'd recommend the H & R -50mm springs. These'll drop your car by around 30 - 35mm. Any lower than that and you'd have to use coilovers and you'll also need to change your front ARB.
    I used a company called www.xsperformance.co.uk who got me 25% off RRP for my Eibach Pro Shocks and 17.5% off my H & R Springs.
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Kool thanks for that tall paul you are a legend on this forum!
    I went onto the site couldnt acces the suspension page so how much did you pay for the eibach shocks and 50 mm H+R springs thats the set up i'll probably go for
    Jason
    A3 1.8TS
    Jun 2006
    831
    Jason
    Their website is a bit pony actually, you'd be best to give them a call and ask for Sal.
    My shocks were 309 and the springs were 130 both prices include VAT. I think delivery was another 9 or so.
    I went for the -30mm springs cos i didn't want my car to look lowered, i think the -50mm springs are about 15 more expensive.
    A3_Turbo's Avatar
    Jul 2006
    1,441
    Thanks for that so do you think the shocks and springs or the re=map?
    How much would a place charge to fit do you think?
    All your help much appreiciated
    Jason
    A3 1.8TS
    Jun 2006
    831
    like i said, i did remap first and i would again.
    Fitting and 4-wheel alignment should have been 194 inc VAT but i also had the droplinks and lower wishbone bushes replaced. The wishbone bushes are a PITA so it ended up costing a bit more.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Pound for Pound Jason, the remap is the one to go for, it's one of those mods that really gives you a big smile from cheek to cheek, especially on a 1.8T. I would however consider doing the suspension first, just to make your car ride and handle a bit better.
    Also consider upping the brakes first before a remap, as suggested by Paul, as you'll find you have too much power for the car to STOP! , especially with winter coming round the corner, stopping is essential!!
    You've got to have a laugh!
