Sky InsuranceEM Tuning
Results 1 to 9 of 9
    Jun 2006
    712
    removing S3 handbrake cover?
    I've searched and cant seem to find anything
    I want to remove the handbrake cover on my pre-facelift S3, it has the centre armrest too.
    does anyone know how to remove it, so I can get it retrimmed?
    cheers
    Jon
    Jun 2006
    831
    It just pulls off over the release button. But you need to pull really really hard.
    In what way are you getting it retrimmed?
    Jun 2006
    712
    I've got a re-trimmed black leather steering wheel and gear gaitor, but with stitching to match my cream leather seats (looks alot better than it sounds, i'll post a pic up later).
    The handbrake gaitor is the only thing left to get done.
    I did try pulling it, but didnt know how hard to, will have to try again!
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    ohhh sounds nice, pics pics pics
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    Jun 2006
    712
    I've fitted a facelift gearknob, so had to get a custom gaitor made. The facelift gearknob one is alot nice than the big bulky pre facelift one!
    Jun 2006
    712
    no joy
    it seems to have some kind of locking mechanism as you can hear it knock against it when you try to pull it off...
    Jun 2006
    712
    still trying to get his off
    someone must know how to?
    Jun 2006
    831
    I wasn't kidding mate. The only way to do it is pull really really hard.
    Even if you stripped the entire handbrake mechanism out of the car it'd still have to be pulled off over the release button.
    The i've removed the plastic one from a SEAT Leon and a Leather one from a Golf. The leather one was harder to remove but it gave eventually.
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Does the lower centre console not have to come out first too?
    I'll try to check ELSA to see if it's actually required when I'm near a copy tomorrow; but if the centre console does have to come out:
    Remove the centre-armrest if fitted: Remove the rear ashtray, then slacken off the big allen bolt on the upper visible portion of the bracket. You don't need to remove it all the way, it just makes it a bit more fiddly to refit, once you feel it coming to the end of the thread put a couple of turns back on it so it doesn't fall out or stress the thread, then try to jiggle the armrest upwards.
    ... The next stage is to pop-up and remove the plastic cover in front of and under the handbrake (ie adjacent to your knuckles when you grab the lever to engage the brake) - I think there are a couple of screws/bolts holding the console down in here. Then there are two or three screws either side under little pop-off plastic covers (the first one is sort of level with the upper centre console in each footwell, so whether there's another one or two each side, just pop-off and unscrew any you find along its length - you'll probably have to slide the seats back to get access to one of them); and finally there are a couple of bolts under the rear ashtray to be removed.
    Once you've done that ideally you need to unclip the gear gaitor and the OBD port (if it's located under the ashtray in your car); but you don't need to do this if you're only lifting the console a little to get a better look at things - just keep an eye on your OBD port (cover removed of course) if you're not going to unclip everything, if it starts to look like it's bending around on its clips, you've gone as far as you safely can without fully unclipping it from the console - don't want to damage the wiring!
    Just watch very carefully as you lift the console; it can easily become marked, and mark the upper (/main) centre console if the two rub together (I found putting a couple of polishing cloths on the obvious places where the two will meet as you lift works well to prevent damage here); and otherwise you just need to keep your eyes on the seat edges and the handbrake area for potential rubbing.
    Like I say, I'll try to check tomorrow if there was any variant which requires you to lift the console to remove the handbrake cover; but at least if there is you've already got the info on how to do it...
    Regards,
    Rob.
