Chris NottSky Insurance
Results 1 to 17 of 17
    Jun 2006
    712
    strange noise on start up & turning off
    noticed this the other day, it doesnt do it every time, but usually when cold
    once the engine is started up, a high pitched whine occurs. If the engine is turned off soon after the noise winds down. it sounds like when you switch off a high powered hoover.
    anyone got any ideas?
    Aug 2005
    Leeds
    144
    My MR2 Turbo made these noises once, i think it was something to do with coolant? there was a smell of burning rubber after a while and chen i checked the coolant i discovered that there wasnt any! and the top of the rubber hose was burning! im probably wrong but worth checking the levels out & see if you have a leak.
    Think i may have heard a similar sound when i owned a 306 but was something to do with the steering?
    Jan 2005
    Colchester, Essex
    147
    I'm sure i read somewhere before about a fan or blower unit attached to the exhaust to stop stalling on start-up.
    Basically it runs on initial start-up for a few minutes to make sure exhaust gases don't back up in the system i think??
    Anybody shed more light on it.....
    Aug 2006
    NI
    785
    i think its for emissions but it sounds like a harsh sucking noise it isnt high pitched.
    back to boost, oh how I missed thee....
    Adams3's Avatar
    Jun 2006
    Hertfordshire
    407
    The classic jet engine noise!! lol
    Its your secondary air pump, very common fault.
    1999 AUDI S3 | AMD STAGE 2 REMAP | MILTEK CAT BACK EXHAUST | VIPER DIVERTER VALVE | EBC TURBO GROOVE DISCS | RED STUFF CERAMIC PADS | 18" RS6 REPLICA ALLOYS | ANDYMAC 'BOSE' UPGRADE.
    Jun 2006
    712
    ive checked all levels and they're fine
    Quote Originally Posted by Adams3
    how hard/expensive is that to fix?
    cheers
    Jon
    Adams3's Avatar
    Jun 2006
    Hertfordshire
    407
    Its about 85-90 quid for the part from the stealers, not sure about fitting though.
    Im just leaving mine how it is!! i like the noise lol
    mad max's Avatar
    sixth gear
    Jul 2006
    beyond the thunder dome
    335
    if your car is pre-facelift it will be secondary airpump,sounds like an old hoover but only comes on when the car is cold think you can have it disconnected
    S3 TUNED AT MRC
    Jun 2006
    298
    PMSL
    Jun 2006
    712
    yeh mine is pre-face lift.
    what does it actually do? I'm guessing it does no harm then, but i'd like to get i fixed, is it easy to do?
    cheers
    Jun 2006
    712
    does anyone know if this is going to cause me a problem? I'd obviosuly like to fix it, but not sure how hard the part is to change?
    any ideas?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Pumps air into exaust system during warmup to heat the cats up quicker. Emmisions device to lower pollution etc.
    Adams3's Avatar
    Jun 2006
    Hertfordshire
    407
    I was told it was to prevent the cats getting covered in unburnt fuel, not sure now!!
    Its still working when its like that but obviously not to its full potential, not really doing any harm!!
    Aug 2003
    Surrey
    469
    The secondary airpump is used to get the CAT up to temp on a cold start. On my Skoda it goes for almost exactly one minute, with revs at 1200, then drops to 1000 and the pump goes off, and engine sounds a lot happier and quieter.
    I had mine checked by the dealer and they said it did seem a little noisy; they cleaned the throttle body and airpump and it has helped a bit. It still does it, but nothing like as noisily. They actually said they found an error code from the throttle body and that if it does it again then they would replace the throttle body. I think I will arrange to drop in and let them check it again before my warranty runs out... a new throttle bosy costs something like 400 quid I think.
    A3 '99 1.8T Sport (Sold 2005)
    2004 Octavia 1.8T Elegance Estate
    Jun 2006
    712
    thanks for the info benk, does anyone know where its fitted exactly?
    Oct 2006
    Norway
    37
    Hangin onto this one too.. I have post-facelift, but also the squeal upon startup.. at first you could think an old car with a screaming auxillery belt, but..
    Did you have yours fixed Jon?
    Jun 2006
    712
    just bringing this thread back up again, has anyone ever had there's replaced?
