Volks AutosBadger5
Results 1 to 8 of 8
    A3steve's Avatar
    Sep 2006
    126
    Servicing Advice 1998 A3 1.8 SE
    Hi,
    I've not long bought a A3 with 89,000 on the clock, I'm pretty sure the Cambelt/water pump havent been done.
    I'm confident to change this myself, But i'm unsure parts wise?
    Looking at old posts, i believe i need a water pump with a metal impeller not plastic - Is this available as a dealer part or somewhere like GSF,eurocar parts?
    On the cambelt side, its advised to change the tensioner, But a friend mentioned a damper as well? what did you have changed when you had yours done?
    I've read a write up for a TT, where the engine mount bolts are replaced, is this true also for an A3?
    What Oil do you recommend and is it usual to flush the system first on audis?
    If theres other things i've missed or you recommend, please let me know.
    Steve
    Sep 2006
    tensioner may be manual or self ajusting
    water pump is avilable from both places
    but if u get a kit will come with all parts needed if you use your engine code ( 3 letters )
    and i wouldnt change the engine mount bolts on a 1.8na
    and yes putting a flush in the oil before changin is always good unless your car has many oil leaks
    A3steve's Avatar
    Sep 2006
    126
    Cheers mate!
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    I don't use a flush. Just get the oil nice and warm before you drain it. Don't burn your fingers though.
    Oct 2006
    Norway
    37
    Quote Originally Posted by Secret Squirrel
    Yeah, same here. I would question the benefit from a flush - Just make sure the engine is warm enough before draining and watch your fingertips as Squirrel here mentioned.
    You'll be off to the moon in happiness afterwards.
    A3steve's Avatar
    Sep 2006
    126
    Cheers for the tips Guys! - Guess ill be busy ther weekend!
    Thanks Steve
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Ah hell, I'll drag this back up. I know changing the cambelt is every 5years / 60,000 miles on the 1.8t unless you're mad... does the same apply for the NA 1.8?
    I ask because someone's just bought a A3 1.8 (2001) at work and it's never been done and it's on 54,000miles.
    rodenal's Avatar
    Oct 2006
    1,982
    It would certainly make sense, as the rubber could easily have perished
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
