Volks AutosChris Nott
Results 1 to 11 of 11
    Aug 2006
    NI
    785
    which engine oil for S3?
    Hey all prob been asked 100 times but which engine oil is good for an S3?
    cheers
    back to boost, oh how I missed thee....
    Jun 2006
    831
    Motul 8100 E-Tech 0W-40 Fully Synthetic.
    Aug 2006
    NI
    785
    thank you sir
    0-40 then if the motul isnt available?
    Jun 2006
    831
    Mobil 1 is probably good enough but not all oils are the same.
    I'd only use Motul and there is no reason you shouldn't be able to find it on the net. Try the opieoils website.
    Jul 2005
    2,488
    AVS or interval servicing? I'd suggest a 5W-30 rather than 0W..
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I do mine every 5K miles with Fuchs 0-40W, from opieoils.
    <Insert meaningless geeky specs here>
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Dealers use Mobil 1 5W 30W ESP formula
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
    PaulRS3's Avatar
    UK
    1,006
    AVS
    vw503.01 (old spec) or vw504.00 (new spec) both are suitable as Audi rejigged their oil specs to confuse things.
    i use castrol * (*whatever the current bling name is)
    Audi RS3
    Jun 2006
    831
    Quote Originally Posted by Dave_Bayern
    Yup, any engine should have it's oil changed every 5000miles or 6 months, irrespective of the Fleet Manager pleasing service schedule the manufacturer recommends.
    0w/5w-40 are both fine. I prefer the 0w-40 as i prefer the extra cold start protection and the cleaning properties for the fine oil lines to my K03 turbo.
    Motul 8100 complies to current and previous VAG specifications.
    May 2004
    170
    Is it only available from Opie oils?
    DamoS3's Avatar
    Aug 2005
    Ireland
    10
    castrol rs 0w-60
