JMB RetrofitsBadger5
Results 1 to 8 of 8
Thread: help missfire
    Jul 2004
    16
    Question help missfire
    Hi i've got an audi a3 1.6 puney 8v. Its been a great vehicle till of late, when it suddenly started missfiring. I've had it plugged into vagcom and it comes up with random cylinder missfire and multiple cylinder missfire. The car hardlt had any power no i just experiance severe juddering say from 0 to 3000 revs
    Its also got lambda sensor open circuit showing as well!!
    Its also started to trigger the traction control light? when i switch the vehicle off the light resets itself
    I've changed the coil pack, and egr valve however still no joy any suggestions would really be appreciated.
    S2Avant's Avatar
    Jan 2006
    Yorkshire
    56
    What year and how many miles?
    Jun 2006
    831
    Errr, your lambda sensor is stuffed?
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    same happened with my S3, i changed the spark plugs (buy the most expensive ones-original) and hopefully that should sort your misfire
    let me know how you get on
    Lee
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    mad max's Avatar
    sixth gear
    Jul 2006
    beyond the thunder dome
    335
    tend to agree with tall paul does sound like lambda sensors gone
    S3 TUNED AT MRC
    Jul 2004
    16
    can the lambda sensor cause the car to judder like hell when accelerating?
    As for the car its a 2001 1.6 with about 74k on it. Any ideas what a lambda sensor would cost and by the way do these cars have 1 or 2?
    Jun 2006
    831
    does your car have a throttle cable or is it DBW?
    Jul 2004
    16
    hi erm i have no idea!! throttle cable is that where you can rev the engine from the engine bay! really not sure if its drive by wire though
