Chris NottVolks Autos
Results 1 to 7 of 7
    Aug 2003
    Lincs, UK
    57
    Has anyone removed a plug from the ECU ??
    I'm having a sneak preview of how to fit cruis control & I need to remove the plugs so I can add some extra wires.
    The problem is I can't remove these nuts, so I can remove the steel retaining cover which keeps the plug from coming loose.
    The nuts seem captive on the top & I can't get access to the screw head from underneath. It may even be that the underside nuts are spot welded to the steel frame.
    Can anyone help ???
    11
    Re: Has anyone removed a plug from the ECU ??
    The steel retaining cover with the strange nuts, does not exist in 2001 S3-TT Models. I think these appeared on the 2002+ models...There should be some way around this problem. I will ask around & inform you if i find something important.
    Nikos.
    Glasgow
    192
    Ahhhhaaa Audi security bolts!! These are easily removed but your dealer and warranty won't be too happy!!!
    Aug 2003
    Lincs, UK
    57
    Pesky Audi Security bolts !!!
    There must be an easy way to remove the ECU. How to AMD, Stealth, etc. do it when retro-fitting cruise. Surely the warranty isn't invalidated by doing this.
    My car was registered in May '02 - chassis no. 8L221016985.
    Has anyone unplugged the ECU of an '02 S3 ??
    Feb 2003
    Kent
    49
    i read somewhere that they need to be drilled off.... but sorry cant remem where i read it
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Yep, pretty sure they will have to be drilled out!
    Rich
    Aug 2003
    Lincs, UK
    57
    finally got round to drilling them out tonight.
    - it's all a bit nerve racking. Made sure all the metal swarf was carefully controlled & removed. Will worry about the possible warranty problems later.
    - haven't fitted the cruise yet, still waiting for more info for the extra loom for the engine bay.
