Badger5Volks Autos
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    is this maf ok to use?
    Hi, i bought a brand new maf from ebay, not a company but someone who bought it for there golf and it was too big, it is for the s3 and has the same code as my original but if you look at the pictures one side has a grill and the other side doesnt, you can touch the sensor im sure this is wrong as mine has a gril both sides.
    Here are the pics http://www.audi-sport.net/vb/vbpicga...?do=view&g=344
    i havent fitted it yet just in case.
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Feb 2006
    West Midlands,England
    44
    thats exactly the same as mine looked like and it worked fine.......that was on a golf though.
    The lack of grill shouldnt matter as the actual sensor is facing the side with the grill, so any harmful objects should be trapped (not that they should get through the filter anyway)
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    sweet, ill go fit it and see what happens.
    Thanks dude
    Secret Squirrel's Avatar
    Sep 2006
    In the Westcountry
    185
    I believe the screens are there to reduce turbulant air-flow throught the MAF tube. However, they do present a restriction.
    They can be removed to increase flow and reduce the pressure drop in the MAF-turbo hose, which could also help to prevent the collapse of the stock hose on higher power cars.
    I would recommend checking the MAF with Vag-Com, if possible. I have heard even new MAFs can be duff straight out of the box.
    HTH
