Monster MotorsportEM Tuning
Page 1 of 3 123 LastLast
Results 1 to 40 of 91
    mnadeem1984's Avatar
    Jul 2005
    Birmingham, UK
    76
    N75 Valve - Vag Com
    Is there anyway you can test if your n75 valve is faulty using vag-com. Also is it possible to check the MAF sensor? Nothings being flagged up on VagCom....
    A3 1.8T 2000X AUM,
    ECU Remap,
    Jetex Full Through Exhaust,
    Uprated Forge DV,
    Pushing 218 BHP
    Jun 2006
    831
    Here's that post again with some more usefull info :
    You need to log each of these blocks in 4th gear on a straight, flat piece of road from 2000rpm to the readline (this my take you over the speed limit so i can't condone doing this on a public road )
    You can log g/s airflow as a test of the MAF (block 002). You claim 218bhp so a figure of 166 g/s at ~6000rpm would suggest your MAF is OK. If you plot g/s v RPM on a spreadsheet chart the curve should also be fairly smooth.
    You can log N75 Duty Cycle, this is how 'open' it's holding the wastegate in % (block 118). This should be a good figure on full boost ie WOT at 3000rpm = ~70%+? Ideally 95% at 3000rpm but that's not hard and fast, really depends on your boost pressure:
    You can also log requested boost and actual boost which is a good check for a leak (block 115). If you requested boost is pretty much meeting actual then your N75 is OK. As for what your actual boost pressure should be... Well lets say your peaking @ 18psi (a sensible number for a remapped K03s)... VAG-COM measures boost in mBar but this figure includes atmospheric pressure so you'd need to apply this calculation: (Boost-1013.25)/1000x14.50377. In other words you'd be looking for a peak boost value of 2300-ish in VAG-COM (assuming you are peaking @ 18psi). If you have a boost gauge then you'll know what you should be getting. Again plotting both requested and actual (2 seperate lines) v RPM on a chart will make it easier to interpret.
    squale's Avatar
    France
    24
    Thumbs up
    Quote Originally Posted by Tallpaul
    Hi !!
    On my ABT S3, Duty cycle is max at 84.3%, does it mean that my N75 F is faulty ? Moreover i have flat spots in boost and the target boost is not reached.. any idead ? (My Maf is ok)
    Thx !!!
    S3 8P '07
    Jun 2006
    831
    Quote Originally Posted by squale
    Hi !!
    Thx !!!
    Small boost leak?
    Duty cycle is probably ok, but by how much is your actual boost not meeting requested? At most points over the rev range it won't but probably between 4000 - 5000rpm it should be very close.
    squale's Avatar
    France
    24
    Small boost leak?
    I'll post a graph in some minutes, btw if i had a boost leak i think the N75 would be near 100% duty to compensate ??
    S3 8P '07
    Jun 2006
    831
    I don't think the N75 is allowed to close the wastegate 100%, one of the many in built safety features of the ECU.
    squale's Avatar
    France
    24
    Smile
    Maybe but you told about 95% duty, thats not my poor 84.3%
    S3 8P '07
    Jun 2006
    831
    84.3% is low, should defo be hitting 95% at 2500-3000rpm.
    Your N75 could be faulty, then again it might not. I take it from your signature that your car is remapped?
    Post up the boost graphs, it may give a clearer picture?
    Jun 2006
    831
    Might also be worth checking the CF's for the timing on each cylinder...
    and perhaps checking the throttle body...
    loads of things it 'could' be... No fault codes then?
    Jan 2006
    Glasgow
    51
    Hi guys,sorry to butt in but you seem pretty clued up on the working of the audi engine.Would the N75 valve being faulty cause my problem??
    Here is my thread,
    Boost Pressure Problem??
    Just so i can either discount it or say it maybe a possibility that its this thats faulty.Thanks.
    Jun 2006
    831
    Sorry fella, i don't really know that much about the 1.8T - i know even less about oil burners...
    If you paid a garage to rectify this fault recently then i'd go back to them and ask questions.
    Any self diagnosis is gonna require VAG-COM.
    dubhyper's Avatar
    Illegally Street
    Aug 2006
    B/wood
    128
    Jun 2006
    298
    Can the logging of MAF readings and Actual Boost vs requested be done in the shareware version of VAGCOM (3.12 btw)??
    Andy
    Jun 2006
    831
    IIRC you can only log the first 25 measuring blocks on shareware VAG-COM so you can only log the MAF, not boost.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Hey guys, I've done a few tests with VAG.com. Followed your instuctions Paul, and just wanted to check a few things. Ok I still need to do MAF test later, but I've done the test for Block 118 (N75) and 115 (Boost). Now for the N75 reading it peaked at 2440 rpm with N75 being 91.4%, now is this normal? @3000rpm it was 48.6% too low?.
    Second question was boost pressure. Now it logged "Cmd Pressure" & "Press @ Intercool" so I wasn't sure if that was requested vs actual boost. But this is what I got. Now there's a bit of a difference and I was wondering if that was due to my FMIC and SMIC being connected instead of the one FMIC? anyway any help would be much appreciated as I am new to VAGcom and wanna learn more
    P.S. I did the little calculation for finding boost pressure and I think mine is running at 12psi, is that around normal for a 225 S3? figures were (1870mbar @ 4680rpm)
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    Jun 2006
    831
    errr, did you lift of the throttle or did the TCS cut in when you did those logs?
    what gear were you in?
    Oct 2006
    86
    Hi Defratos,
    Your graphs are interesting, what caused the dip in the middle, did you back off or change gear?
    I have done some tests with my 2001 S3 with SPS3 comparing the different boost settings available of the Revo SPS 3. As you can see, my actual boost is a little way off the requested boost in both instances. I am suspicious i may have a small leak somewhere. Poss the same for you.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Hummm, ok I think I did let go a lil "on comin car" didn't realise at first lol. I'll do the test again later and see what happens. I was in 4th gear from 2000rpm -redline
    Audi S3-BAM
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    was my boost pressure reading of 12psi sound right?
    Audi S3-BAM
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by Defratos
    Standard car, no remap? Sounds about right.
    [/sarcasm]
    Oct 2006
    86
    I think 12psi is a little low.
    If you look at my graph you can see maximum boost is about 1.5bar which is 21.75psi.
    I would expect aou 14-15psi for a standard S3..
    someone ( paul! ) correct me if im wrong
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    I thuoght the S3 ran at 0.9bar in standard form? 13psi. Might well be wrong
    [/sarcasm]
    Jun 2006
    831
    12psi sounds spot on to me.
    Loftgroover... Are you just altering the boost settings? have your tried playing with the timing too? What fuel and mods do you run?
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    humm, well anyway here's another graph (no dip in this one), still a difference between the two (possible leak?)
    Audi S3-BAM
    Jun 2006
    831
    Defratos... this is a plot of boost on a stock SEAT Leon Cupra R (210bhp). Not a direct comparison but basically the same engine, you can see how boost meets requested very well. Your plot is a little odd, could your pressure drop be due to your FMIC?
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    yeah I think so, Someone on here has told me I'd get a huge difference in pressure between the two ICs. Hopefully gonna be upgrading soon to just the single, maybe that'll sort it out. cheer for the help though
    Audi S3-BAM
  28. #27
    Jun 2006
    831
    The thing is, the S3 on stock boost doesn't need a FMIC. As your plots show, you are actually losing power because of the extra volume. The two stock SMIC's are very capable of maintaining a sensible inlet temperature.
    If i were you, i wouldn't waste more money on expensive mods that give negligable gains. Go get yourself REVO and an SPS3 and keep your FMIC. If you run V-Power then with that FMIC you'll be able to wind up the boost and timing and watch your car fly.
  29. #28
    Oct 2006
    86
    Paul,
    Im running fuel at setting 7 on the SPS using V-Power. Slightly cooler plugs.
    I think there might be a small boost leak as your SEAT graph demonstetates. What you think?
    Also, ive logged the data on a friends S3 and get the following, boost not following requested and then being well over the requested ( N75 checked and working OK), any ideas? What casues the dip in the middle?
  30. #29
    Jun 2006
    831
    hmmmm, your timing is a little agressive; and maybe you are running too higher boost too?
    Try Low Boost 9 Timing 6?
  31. #30
    Jun 2006
    831
    Actually, you've probably got an SPS3 v1.1 so try Boost 6/7 Timing 6
    and read this: http://www.revotechnik.com/products/...uide060406.pdf
  32. #31
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Hey there mate, ok I know what Revo is but whats a SPS3? and V-power?
    Audi S3-BAM
  33. #32
    Oct 2006
    86
    Hi Defratos,
    Sorry, SPS 3 is a Revo product that allows the user to adjust the boost
    and ignition timing that the ECU uses on the car to enhance performance., But, as Paul is indicating, this should only be used with some sort of monitoring software such as VAG-COM so the user can monitor the effects.
    V-Power is Shell's new product name for Optimax, a pump fuel with 98 (99?) RON that allows the engine to run more aggressive ignition timing safely.
  34. #33
    Oct 2006
    86
    Hi Paul,
    No, i have the later SPS version with high and low boost options.
    Are we refering to my car (first graph) of my friends car? I have logged my CF on all cylinders and almost none is applied, it seems the 1.8T has fantastic active knock control, plus im running v-power.
    As for my friends S3 ill try and log CF as well and bring the boost down a little.
    You private user or have business in cambridge?
  35. #34
    Jun 2006
    831
    Quote Originally Posted by loftgroover
    lol, very much an amateur!
  36. #35
    Oct 2006
    86
    Ha ha, ill start ignoring your advice then
  37. #36
    Jun 2006
    831
    I wondered why anyone listened in the first place!
  38. #37
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Hey there guys I want to ask something. How do I go about keeping the same pressure throughout the exchange from Turbo to IC to Manifold? I've heard keeping the diameter of the pipes the same throughout would help. Just wanted to ask whats the Forge FMIC outlet size is? and what size outlet should I not go over? I've heard 2.5" outlet is the biggest any bigger will lead to pressure drop?
    Audi S3-BAM
  39. #38
    Jun 2006
    831
    i see you're ignoring the remap advice then...
    2.5" Intercooler Hosing in sufficient. IIRC the Forge FMIC uses either 2" or 2.5", i don't think it's as wide as 3".
  40. #39
    Oct 2006
    86
    Unfortunatly the laws of physics stse that any obstruction in the system will cause a pressure drop, the more obstructions, the greater the drop in pressure.
    In order to have as much of the compressor outlet pressure at the manifold you will need to have as few bends as possible ( and where there are make them as gradual as possible) and you will need a free flowing intercooler. ( others on this forum will have more experience so ask about the best coolers)
    Remeber though, you need to trade carefully between free flowing intercooler and charge air temp reduction. Its no use having very high pressure air in the manifold if its at 150 deg C!
    Turbocharger outlet pipes are sized quite specifically in relation to the gas velocity leaving the turbo, and too large a pipe will become an issue, what that size is though, i have no idea!
  41. #40
    Oct 2006
    86
    You will gain far more in the short term from a remap and good fuel..
    you only need to worry about the charge air cooler when it is the only item in the system thats a restriction, and im guessing youre nowwhere near that yet!
