Volks AutosEM Tuning
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 91
  1. #41
    Jun 2006
    831
    Defratos is losing about 2psi at the top end.
    Assuming the pressure drop IS because of his FMIC and not a simple boost leak, then that amount is excessive. A drop of 1psi is 'normal' for a FMIC.
    BUT... Defratos is running the Stock ECU and hence stock boost. The S3 doesn't need a FMIC at that boost, it simply doesn't generate the charge temps, especially in winter. If his logs are recent then ambient air must be less than 10C, i'd be suprised if he was hitting more than 35 - 40C inlet temps with a FMIC - I get 60C!
    So, basically he's introduced a pressure loss that the car doesn't need. He's not even offsetting that against a usefull drop in inlet temps because the car doesn't need them either! It'd be interesting to see what CF's he's getting cos i doubt even without a FMIC that an S3 needs any timing correction, except perhaps on the hottest of days or running the sh*ttest of 95ron fuel.
    Get a remap and whack the boost up, use 99ron fuel (v-power) and you'll be able to run aggressive timing and boost with that FMIC. Then it won't matter if your actual boost isn't quite meeting requested because you just won't care. I'd also imagine that the differance between requested and actual would reduce to much nearer the 1psi mark. At which point spending 750 on a Forge FMIC would be pointless!
  3. #42
    Oct 2006
    86
    Its true, the SMIC will be more than capable of dealing with the charge temps produced by the K04 at std boost, or even at higher boost.
    If the FMIC is causing that pressure drop, i think this may be a case of bigger is certainaly not always better.
    Th S3 runs active knock so it will always advance the timing ( within limits ) to the point of knock and then add the correction factor based on the knock sensor output. But in standard form it will be very little if any as you suggest.
  4. #43
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Quote Originally Posted by Tallpaul
    i see you're ignoring the remap advice then...
    2.5" Intercooler Hosing in sufficient. IIRC the Forge FMIC uses either 2" or 2.5", i don't think it's as wide as 3".
    lol no mate, that's coming soon "hopefully" probably more like next year . What you're saying makes sense (a FMIC is not needed on a standard S3) and I'm not planning on splashing out on 700 for a Forge, more like 150-200 on just the core unit and fit it myself, hopefully just before a remap, should sort things out a bit. cheers for the detailed feedback mate
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
  5. #44
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Quote Originally Posted by loftgroover
    Unfortunatly the laws of physics stse that any obstruction in the system will cause a pressure drop, the more obstructions, the greater the drop in pressure.
    In order to have as much of the compressor outlet pressure at the manifold you will need to have as few bends as possible ( and where there are make them as gradual as possible) and you will need a free flowing intercooler. ( others on this forum will have more experience so ask about the best coolers)
    Remeber though, you need to trade carefully between free flowing intercooler and charge air temp reduction. Its no use having very high pressure air in the manifold if its at 150 deg C!
    Turbocharger outlet pipes are sized quite specifically in relation to the gas velocity leaving the turbo, and too large a pipe will become an issue, what that size is though, i have no idea!
    Cheers for the clarification, mine at the moment has a few bends, hopefully I'll get around to sorting that out when fixing the FMIC (before remap), thanks for the lil lesson in physics (I was never quit good at that in school )
    Audi S3-BAM
  6. #45
    Jun 2006
    831
    Quote Originally Posted by Defratos
    So are you going to change to a FMIC similar to Dubhyper's or have Forge quoted you that sort of price for supplying their core?
  7. #46
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    well I want something similar to Dubhyper but I'm not too sure about it fitting right. Probably going for something of E-bay with similar sizes to the Forge, no way in hell am I paying silly money again (already spent too much on the current FMIC)
    Audi S3-BAM
  8. #47
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    more like something like this:
    http://www.ht-tune.com/apps/keraily/tuote.aspx?o=68&t=1
    Wohooooo 1,001 posts achieved lol
    Audi S3-BAM
  9. #48
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Any idea how I can check my BHP with Vagcom?
    Audi S3-BAM
  10. #49
    Jun 2006
    831
    lol, so yet another unproven intercooler. well, good luck.
    Although you should still try the remap before you change FMIC. After all, it will improve the pressure differential and you have no idea whether a new (unproven) core will be any better; it could be worse!
  11. #50
    Jun 2006
    831
    You can estimate it from your g/s airflow. Only a rough estimate though.
  12. #51
    Oct 2006
    86
    If you are handy with excel ( which it seems you are !) have a look here: http://www.ross-tech.net/vag-com/exa...0_Tutorial.xls - This generates a Horsepower and Torque graph using the calculated torque values output by Bosch ME7 ECU's
  13. #52
    Jun 2006
    831
    I think the torque figures are even more fanciful than the bhp ones, but they are usefull estimates.
  14. #53
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    sweet, cheers mate
    Audi S3-BAM
  15. #54
    Oct 2006
    86
    BHP is calculated from torque so if one is right they should both be right ( or wrong!)
    Alternatively, you can convert your g/s MAF into lb/min and use 9 hp per lb/min of airflow, but now we really are guessing...
  16. #55
    Jun 2006
    831
    sorry, i meant the torque figures calculated from engine load are even more fancifull than bhp calculated from air flow
  17. #56
    Oct 2006
    86
    I think we're all speculating now..
    On a different subject, ive logged 198g/s @ 6240 airflow on block 002 on VAG-COM - is this what you expe ct from revoed S3? seems a little low.
  18. #57
    Jun 2006
    831
    Apparantly (according to REVO) anything from 190g/s up is acceptable.
  19. #58
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    whats the g/s supposed to be on a standard 225 S3? if anyone knows?
    Audi S3-BAM
  20. #59
    Jun 2006
    831
    160g/s+
  21. #60
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Tend to get in the 180g/s+ range on my standard S3. Usually about 185. Yep it is standard, had it since new, first owner etc etc.
    AL
    '07 Phantom Black S3 - '07 to now - Bucket Seats, FBMFSW, BOSE, Symphony II+, Cruise Control, Elec Folding Mirrors, Front Centre Armrest, Rear Armrest & Through Load, Interior Light Pack, Luggage Pack, Reversible Boot Mat, Luggage net.
    '02 Silver S3 (225bhp) - '02 to '07
    '99 A3 1.8T - '99 to '02
    '11 Rising Blue Golf R - '12 to now - 19" Black Talladega's
    '52 Black Golf GTi MkIV Anniversary - '03 to '12
  22. #61
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    right I just did this and got 154hp with 176lbft now am I missin something? or am I doin it wrong? cause shouldn't I have more like 200hp?
    Audi S3-BAM
  23. #62
    Oct 2006
    86
    can you post the raw excel data, ill have a look tomorrow while at work!
  24. #63
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    sorry for the delay, just realised someone replied. Ok not too sure how I can post it? I can e-mail it to you if you're ok with that? or if you can tell me how I can post an Excel doc on here?
    Audi S3-BAM
  25. #64
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    I did the same test earlier on today to try and see if I did something wrong, but I got nearly the same, actually lost 2hp lol.
    Much smoother curve
    Audi S3-BAM
  26. #65
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    As for my MAF, for some weird reason I only got 130gs
    Audi S3-BAM
  27. #66
    Oct 2006
    86
    Hmmm,
    130 is very low. My S3 made only 160hp with a faulty MAF, can you log the boost pressure, block 115?
  28. #67
    AL_B's Avatar
    1,564
    Its bloody low, you sure someone hasn't put a 1.6 in it?
  29. #68
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    maybe a faulty MAF buddy? would also explain the low power (130g/s equals around 160hp)?
    how does the car feel?
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
  30. #69
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    humm, well anyway here's another graph (no dip in this one), still a difference between the two (possible leak?)
    This was block 115. Do u want me to mail you the excel bit?
    Audi S3-BAM
  31. #70
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    The car feels solid to be honest, maybe a bit laggy, but now way does it feel like 150bhp lol honestly I hope I'm doing something wrong, cause the car seems quick "I think". Do u think my back box would restrict the power by that much?
    Audi S3-BAM
  32. #71
    dultanur's Avatar
    Sep 2006
    Istanbul,Turkey
    407
    nope, unless it's solid
  33. #72
    Oct 2006
    86
    unless your back box was completly blocked there is no way it would lose 40+ bhp.
    Your boost is about .75bar max ((1750mbar-1013.25)/1000) which is about right for std S3.
    Firstly, i would ignore the calculated power output and concentrate on getting your MAF reading OK, when this is done you can go back and see what the power readings are....
    Do you have a friends S3 or TT you can swap the MAF over and log again, as if the ECU thinks there is only 130g/s air mass it will adjust fuel accordingly and your power will be significantly reduced.
  34. #73
    AL_B's Avatar
    1,564
    Defratos,
    This may be a daft question, but have you tried unplugging the MAF, does the car feel better?
    When I've been investigating MAF problems, I've unplugged the MAF, I've never done any logging at the same time. MAF readings might be zero, but also the ECU might revert to basic settings and perhaps give a fixed value XYZg/s? Who knows? Would be interesting to see.
    AL
  35. #74
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Would a MAF from a 2002 V6Golf work? I'll try sorting out the MAF reading first, I should be looking around 160 right?
    Audi S3-BAM
  36. #75
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    Quote Originally Posted by AL_B
    Defratos,
    AL
    never tried unplugging it but I guess its worth giving it a go. Will let u know how it goes
    Audi S3-BAM
  37. #76
    Oct 2006
    86
    Check the MAF part numbers, if same you are OK, if not assume it will give you spurious readings...
    If you unplug the MAF im pretty sure you will get an instant engine warning light on, i believe this will also implement limp home mode so you wont get any decent readings.
    Worth a go but dont forget to reset any fault codes before doing further runs..
    Also have a look on the ross-tech page for throttle body adaption http://www.ross-tech.com/vag-com/cars/throttlebody.html might make some difference.
  38. #77
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    u know what I just remembered when I did checkes to see if I had any fault codes I got one, something to do with the boost pressure or valve. I'll do a fault check later on today and see what happens. cheers
    Audi S3-BAM
  39. #78
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    2,230
    u know what, I've cleaned and changed a few bits before I tried VAG on it, I should have taken test results before I started changing bits and cleaning them. I'm thinking this could be down to a few things:
    1-DV I cleaned it a few weeks back and put on the springs some grease (the same one I use for my gear shift) and I'm not sure if that's ok, it said don't use any silicone based stuff, and I don't think this was.anyway..
    2- installed new samco pipes from Turbo to SMIC and from FMIC to throttle body.
    3- I also cleaned out the throttle body but with it fully closed, now I think I shouldn't have done that, and I think it's something to do with the throttle body, what's the right way of going about doing this properly? do I need to have the engine on?
    I think that's about it, ohh no
    4- I changed my MAF to a slightly bigger one with a 4.bar FPR now this could be doing something, but it shouldn't give me the results I'm getting now.
    5- I also unplugged the battery lol
    I'll be looking at a few things over the next week, will let u guys know how I get along, thanks for the help
    Audi S3-BAM
  40. #79
    Jun 2006
    831
    lol, nothing like a bit of logical fault finding
    So, what are your peak g/s now you've fettled everything?
  41. #80
    Oct 2006
    86
    "4- I changed my MAF to a slightly bigger one with a 4.bar FPR now this could be doing something, but it shouldn't give me the results I'm getting now."
    I think thats the first place to start, the MAF will be sized for a different capacity engine so may give you spurious readings..
